Afternoon all,
Does anyone know of a Hydraulics type fittings supplier that doesn't mind taking orders for a couple of small parts? I'm after a couple of
1/8" BSPT male to 7/16" JIC male adapters (plated steel or brass). Apparently they are not very common, and the local suppliers near me
won't order them in
andy
linky
there's loads, just paste the fitting description into google
god my spelling has gone to the dogs...
kept rereading that and another mistake!
[Edited on 15/2/11 by Mr Whippy]
Russ Bost on here
Originally posted by bigandy
Afternoon all,
Does anyone know of a Hydraulics type fittings supplier that doesn't mind taking orders for a couple of small parts? I'm after a couple of 1/8" BSPT male to 7/16" JIC male adapters (plated steel or brass). Apparently they are not very common, and the local suppliers near me won't order them in![]()
andy
not my fault he doesn't know what he wants...
not my fault he doesn't know what he wants...![]()
Are you 100% sure you need 1/8" BSP? 1/8" BSP and NPT are extremly close, NPT is 27tpi and BSP is 28tpi
Had a rummage at work yesterday, wasn't entirely succesful although I did find enough adaptors to go from JIC -4 to 1/8" NPT (JIC-4 x
1/4"NPT nipple + 1/4"NPT barrell + 1/4" NPT x 1/8" NPT nipple) to total length 80mm
Sorry didn't have the right fitting but let me know if these are any help.
Regards
Davie
Thanks for looking Davie.
The fitting has to be a BSPT fitting, as it is going into a cast zinc housing on a pressure sensor, and the datasheet explicitly states that other
fittings (especially BSPP, and NPT) fittings hsould not be used.
I think I've found a source from a supplier down south though, just waiting on a price from them
No problem, sorry I couldn't help
