Can new drivers use their own car for the test still?
StrikerChris - 23/2/11 at 06:07 PM
As above really,and if so does it have to be modern ie safetywise.
i know when i took mine 12 years ago you could but my instructor scare me into paying for his car to take the test saying i'm more likely to pass in an instructors,but i'd of loved to take it in the imp i'd spent 2 years doing up,and i know a young lad who's learning has a classic mini feels the same,but i fear the do good brigade may want airbags etc
rayward - 23/2/11 at 06:18 PM
my daughter passed test in her own car 3 weeks ago so yes,
the only potential problem is if there are any VOSA recalls that have been needed one the particular model/year of car you turn up in you need proof from the main dealer that this work has been done, or they will refuse the test
hth
Ray
martin1973 - 23/2/11 at 06:18 PM
think you can but
it has to have headrests,
and some other silly stuff
should be able to find info on dsa website.
matt_gsxr - 23/2/11 at 06:23 PM
what about in a bec with no reverse. That 3 point turn is going to be interesting!
StrikerChris - 23/2/11 at 06:30 PM
Cheers guys,sounds hopefull. Personally if i was a driving instructor i'd be more likely to pass a lad who can start and drive an old car cammed up on a cold day,juggle the brake and throttle when its stalling at an awkward junction in the cold than anyone who's only been taught to pass their test and have no real idea whats happening,even if the retro kid did touch a kerb trying to park!
UncleFista - 23/2/11 at 06:47 PM
My mate passed his test a fortnight ago in his Jag
morcus - 23/2/11 at 11:17 PM
As above yes but there are quite a few things to bear in mind. All the legal stuff is listed on the Direct.gov site. You must have a second mirror, turn up without and you fail.
Having failed a test in my own car on the grounds of saving money I'd offer this advise, if it's more than ten years old it's far to risky. I spoke to alot of people on this subject including driving instructors and examiners and driving an old car on your test is a massive risk as is your car fails you fail, there are a huge list of things that can be wrong with your car which constitute a fail, My car had a problem with the hand brake warning light which required the hand brake to be forced down hard to turn it off, driving with the light lit is a fail. You can also be failed if your car smells of cigarettes (Testers disgression). If you take your test in a driving school car you won't have these problems and if the car fails you you'll be refunded (With BSM at least, I can't speak for any other school).
I've often wondered about what happens if you take your test in a car that's too long to do a three point turn or too wide to fit in one of there parking spaces as nothing in the rule specifies maximum dimensions.
As I took a test about 3 years ago in a 205 you should be alright in a mini as long as you've got seats with head rests, I got told off because mine was in the 'wrong position' and I could move it with out getting out but I didn't get marked down for that. For the record the car didn't like switiching between backwards and forwards and jammed in neutral on a hill.
StrikerChris - 24/2/11 at 05:07 PM
Whether he will or wont i dont know.thanks for the replies.as i said before,i took mine in an instructors car cause he scared me into it,i only had an instructor cause dad wanted to know the test routes and hadn't seen a highway code in 30 years,had been driving his landrover since i could touch the pedals!
Glad to hear you can pass in your own car tho!
