Just having a rant about not being able to get the clutch cable of the XR4x4. I really need to as the clutch has let go, will it come of, will it hell. Think I need a big crow bar and some vice grips. Rant over.
have you released the ratchet on the pedal ?
yeah ford had a crap plastic tooth ratchet thing at the pivot of the clutch pedal you have to lift the claw of the ratchet to let it slip to the plain section then the cable will be slack
Pulling the cable inner should release the ratchet but if it doesn't then get someone to pull the pedal up at the same time as you pull the inner and that should do it.
Originally posted by scootz
Think the rachet and pawl has siezed. Done hundreds of Fords over the years and never had this problem, just my look. 6ft tall, 18 stone in a confined space under the dash to change it.....I don't think so. Think I'll get my son to change it.
