If you are considering using an RX8 engine then bear this in mind.
If the water pump ever needs replacing, could you bring yourself to ordering and fitting the required gasket?
http://www.atkinsrotary.com/store/product.php?productid=17416&cat=620&page=1&js=n
The manual states:
Remove covers insert gasket
Should that be greased before it is inserted?
I've heard it leaks at one end
Looks exactly like kames racetrack except it hangs the other side!
http://goo.gl/maps/vRn6
[Edited on 5-5-11 by v8kid]
Sorry don't see the issue.
Mind you what is it made out of if it weighs 1lb?
mastic!
hA
I was'nt expecting that
as my 30th birthday nears, the smutty comments went straight over my head
I honestly didn't realise until I showed someone else.
Originally posted by liam.mccaffrey
as my 30th birthday nears, the smutty comments went straight over my head![]()
I looked at this post earlier and thought 'oh maybe there's some technical reason it would be difficult to fit' and 'I am a bit of a mechanical duffer so I won't comment less I look a fool'. Then I look back and realise that it looks like a big willy and your all immature. hehe
Wow..... you know those designers had to have a good laugh about that. VERY subtle.
I'm thinking I need a bigger gasket now
Very similar to the 3S-GTE one:
How childish and immature.....
Does look like a knob though....
