i have a 04 skoda superb 2.5tdi v6 with no power/pull i seem's very flat i have so far replaced air mass sensor,changeover flap,boost pressure
sensor ,can't see/hear any air leak's and the turbo has been sent to a turbo centre and all is good and to top it off no fault code's
hellllllllllp
These symptoms are normally associated with intercooler pipes coming adrift or a punctured intercooler. The pipes have special clips which can let go, renewing them is the only remedy.
My Saab turbo has had similar issues twice over the years, and both were intercooler pipes.
The bottom one was loose, hidden under the mass of pipes & stuff, and wasnt too obvious till I realised the clip was loose.
The second time was the easier one, when the plastic hardpipe into the throttle body popped off.
Sounds like a leak in the intercooler pipework or a blocked exhaust.
Best bet would be to make a simple boost hose tester. Block each end of the intercooler pipework and pressure test it with compressor.
thanks for the info blocked exhaust was the problem
