Revcounter Question?
Chippy - 26/8/11 at 07:03 PM
Hi, Possably a stupid question but anybody know if its possable to run a revcounter in the same way as a speedo, "ie" with magnets on the crank or flywheel, and if so what would you need. Reason for asking I want to run a petrol revcounter on a diesel engine. Cheers Ray
Edit to add, can't use the alternator as it hasn't the tappings.
[Edited on 26-8-11 by Chippy]
rusty nuts - 26/8/11 at 07:35 PM
Doubt if just any rev counter would work that way but have you thought about using a diesel rev counter ? IIRC the old Nissan Bluebird diesel used a sensor picking up from a 4? legged disc behind the crank sprocket, Peugeot and Citroens work by picking up off of the flywheel
r1_pete - 26/8/11 at 08:03 PM
Try googling tachometer generator, and see if it gives you any leads, the 3.8 E Type and other jags used such a device on the end of the inlet cam.
