diesel oil in a petrol engine
mookaloid - 21/7/12 at 10:20 PM
Daughter's golf - brought it round today for me to fix a vibrating speaker.
Whilst there I checked the oil - needed a longer dipstick to be able measure the actual level so thought it best to put some oil in before driving it any further.
I only had a can of 5W 50 fully synthetic diesel oil which I haven't needed for years, so on the basis that this is better than no oil - in it went.
What do we think? is this ok?
M
ReMan - 21/7/12 at 10:36 PM
It will be fine.
But I'd look at changing it if its a new car, if not just run it and top up with normal next time
mookaloid - 21/7/12 at 10:48 PM
Originally posted by ReMan
It will be fine.
It's a 2000 year 1.6 8v - hardly new
Staple balls - 21/7/12 at 11:36 PM
Probably be fine, I'd just swap it to the right stuff when you get chance.
RichardK - 22/7/12 at 04:12 AM
Give it a couple of days and you'll have forgotten you ever did it anyway,so all good mate!
britishtrident - 22/7/12 at 07:42 AM
Not a problem as a general rule diesel engine oils meet the specs or petrol.
Slimy38 - 22/7/12 at 08:34 AM
When I was in Halfords getting some oil for the tintop I did notice a selection of oils that were 'petrol/diesel'.
The only thing might be that a 5-50 weight oil won't be too good for that age of car. My personal preference for older cars is a slightly thicker semi. But only a top up won't affect the overall weight that much.
madteg - 22/7/12 at 08:36 AM
Depends on what oil you have used, i had a very expensive experiance when i did it.
Used to work for a bus company where i could get oil for free, anyway car started to smoke on overun after about a month. (Rebuilt engine) Still smoked could not under stand why, till someone said did you use the bus oil with detergent in it. Drained oil filled up with petrol oil and instantly OK. Did notice when i stripped engine there was no carbon deposits and all internals where spotless. This was 20 years ago tho.
chillis - 22/7/12 at 09:06 AM
Depends on age of engine but all the engine oils I have in the garage say suitable for petrol and diesel engines.
It is true that years ago diesel engine oil had more detergents in and this would attack oil seals and cork gaskets. Modern diesel oil has less detergent in and modern engines use diesel type oil seals and different gaskets to cork. If your at all concerned then drain the oil, change the filter and you will be good.
britishtrident - 22/7/12 at 10:17 AM
A few points
To meet 5w/50 viscosity range the oil must be a very good quality oil I am pretty sure it will be fully synthetic, the normal oil recommendation for this car in the UK climate is 5w/30 so a 5w/50 should cause no viscosity problems.
Synthetic oils have need much lower levels of additives than mineral oil.
Even the cheapest supermarket synthetic oils stand up to the hostile conditions in the engine crankcase much better than mineral oil, they also provide a much better oil film on the rubbing surfaces.
Engine oils in diesel engines are subject to harsher conditions than in petrol engines for this reason have higher levels of additives to counter the formation of sludge, varnish and control the acidity of the oil. However as with synthetic oils petrol engines in a synthetic oil for a diesel the ammount of additives in the oil is much lower than in a comparable mineral or semi-synthetic oil. Nearly all modern oils meet the requirements for petrol or diesel engines. The main exception is a diesel where a PD oil is required.
The only reason for preferring a mineral or semi-synthetic engine oil on an old (eg early 1960s or earlier) car engine is that mineral oil keeps natural rubber oil seals from shrinking.
