Might sound like a strange question but if you wanted a car at least as big as a late 90's rep mobil that was as light as possible what would
your options be?
This came from something we were discussing at work about how cars get heavier and heavier and the more I think about it the more curious I get.
The problem i see, that you could build quite easily a very light rep car, and this would make it very fuel efficient
but the miniute it hits a "normal " rep car Audi/BMW/Merc etc, you would be pulverised by the over engineered build and mass of a car
weighing nerly two tons
I understand why cars are heavier, and that in a crash in something superlight weight your going to come of worse. I saw my mate Citroen AX after
someone hit that, the front of there car got almost to the centre line of the AX in a side on crash, noone was in it fortunatly.
This is all hyperthetical though. Best answer we came up with was Mk2 cavalier, which all of us had experience of but none had driven.
As I see it there is no reason that a big car has to be heavy, the main reason that they all are has little to do with "crashability" it
more because of all the add ons that the manufacturers seem to think we all need. I guess that a heavy car rides better, but even there if enough
effort was put into the design don't see why a light car couldn't be made to do the same. When I was a kid my Dad was a firm Jowet fan and
had a few, I think they were called Light Sevens, absolutely gutless but they were very big cars, (in the day), and they weighed next to f**k all, but
very comfortable to ride in, but not even a radio, let alone air con,
. Alloy bodies on an ash frame, with a horizontaly apposed twin cylinder
engine. Happy days! Cheers Ray
I used to have a 1970s Rover P6/3.5l V8. The official workshop manual says that 1173 kg with all fluids, which is about 150kg less than a focus or
150kg more than a fiesta. The only reason I remember that is because I used it as my PIN for years!
Regards
Hugh
ETA - it had air con and a radio and a full sized spare in that weight too.
[Edited on 29/8/12 by hughpinder]
I had of of those as well
However I did not believe the hp figures either and it felt heavier to drive. IIRC around that period the data was highly suspect.
Mk1 cortina would be my choice for light body but I think the question may be aimed at modern cars and they are all heavy sods!
Cheers!
Renault 21
the 1.4 litre one we have used to be 980KG
yes 1.4 the same as R5 used to have due to tax reasons here in Greece back in the 90s
Vauxhall Zafira is fairly big and weighs just over 1400kg. Lightweight compared to the Ford S-Max at 1900kg.
French stuff is normally pretty lightweight.
Pug 405, Citroen BX
A Rover SD1 V8 Vanden Plas only weighed 1313kg, a Sierra 2.0L Ghia only 1094kg and a 2.0L Mk3 Cavalier about 1048kg.
It's incredible that a new 1.6 Focus weighs around the same as a V8 SD1.
Renault 21 TL 955kg. Pretty decent sized car as well.
[Edited on 29/8/12 by MikeRJ]
Doesn't have to be modern, but something you could get a drivable example of was more what we were aiming for without it costing the earth.
Mercedes did an experiment last year and put a modern engine into a late 80's 190, the car was much much lighter than its modern equivilent and flew !!!
It must of been going some to have actually taken off.
volvo 240 saloon .......
volvo 740 saloon .......
around 1300kgs , estates normally 50-100 kgs heavier
Rover P5b 1587kg. Like driving your favourite armchair. But it could hustle, even with an auto box
Also a second for the Mk1 Cortina. (with a modern engine) 787kg
[Edited on 29/8/12 by jollygreengiant]
Just been looking around and maybe these would be ideal candidates for a newer engine? It would be interesting at least to see one take off at the lights with the XM's un-sporting look![]()
Most mid sized cars of 20 years ago were relatively light and still fitted with reasonable engines. The problem is finding a 20-25 yr old car that is
still going
Mk2 Cavalier SRi, Ford XR3i and loads of earlier Jap cars went well
I still have a soft spot for the Alfa 164 - more executive than repmobile , but at just 1500 kgs , all the toys you could want , and Gods own
engine...........shame theres so few left
