Guys, I have a modular sequential gear change mechanism designed that I'm going to use in my Tiki project.
It would be adaptable to most mid or front engined cars that use cable gearchanges.
Does anyone see any commercial possiblities in a product like this, bearing in mind It will be a lot cheaper than anything on the market already?
Or maybe just build my own and forget about?
Any thoughts?
Alan
If it will convert a 5 or 6 speed H pattern box then yes
Would also be adaptable to paw shift as well
How does it deal with reverse?
Not sure what you are planning but if it's well designed and well manufactured and reasonably priced and for a commonly used engine/gearbox
combination I think there will be a good market.
Even bigger pent up demand for something to adapt to the Type 9 RWD gearbox with reverse - success will depend on reliability.
I think you should build your one and test it thoroughly before considering marketing it.
Originally posted by Ivan
Not sure what you are planning but if it's well designed and well manufactured and reasonably priced and for a commonly used engine/gearbox combination I think there will be a good market.
Sounds interesting. Will it handle pressing the clutch / rev-blipping as well?
I mean, will it do those for you? Not sure I see much advantage if it doesn't press the clutch for you?
Ikeya sequential shifters are available and have been for 8-9 years in Japan
mostly Jap model specific boxes, Nissans (i had one), Evos etc.
if you made one for a Type 9 or T5 i reckon youd have a great market.
the ikeyas are between £850 and £1250 in the UK btw
http://www.ikeya-f.co.jp/en/index.html
click on one of the car images for videos in operation
A bit of further reading for the OP
http://www.gtr.co.uk/forum/170149-anyone-tried-ikeya-sequential-shifter.html?highlight=ikeya+sequential+shifter
Thought about this myself a few times but always come back to the fact that thereseems little point. Doesn't mean there is no market though.
The shift will be as slow as an h shift?
More good input...cheers all.
I think I will just build one for my project, test and develop it to death....then look at the commercial possibilites....if I'm still
interested...
Personally never managed to mis-shift an H box (though I know people who have) and I don't think a paddle shift conversion will stop you from
missing a gear without some clever electronic control rather than mechanical.
I've heard in more than one place that H>paddle shifts generally work out slower to shift than an H box alone. The kid in me likes the idea,
the logical analysis says different. I'd quite like to robotise a box but I'd need to run a hydraulic pump too to push teh clutch and
that's even more crap to carry around when you could just use the same method that's been fine for decades
[Edited on 11/12/12 by coyoteboy]
When at 11/10ths its easy enough to mishift an H pattern. As you have your hand on the shifter and go kerb hopping on circuit, the reulting jolt
affects the whole body inc the hand and can pull the lever too far/not enough across the gate. Very lilely in rallying too.
The sequential shifters take out some of that inaccuracy, as so long as it goes back or forth far enough, any side load doesnt effect the shift.
On 'real' sequenti race boxes, they use dog rings for gear engagement so you have to have zero mechanical sympathy and slam the gears in, or
yiu risk excessive dog wear or breakage. Same goes for H pattern dog boxes, so again sequential takes out some of the possibilties for screw up
the lotus on that japanese link uses the clutch operated by the foot. not really convinced by theyre product.
the ikeya and the OPs suggested project i assume, just changes the shift pattern. If you want clucthless too, thats a different game, unless you have
the shifter mech attached to a 'dog box.
i had one of the ikeyas and they are fun but ultimately not essentail enough to carry the weight on a hillclimber just because i wanted to be a tart!
I'm aware of the mechanical issues with all of the gearbox types, I've just never found I mis-shift but I'm also probably not that fast
at shifting to be fair.
But converting an H to a seq conversion would stop this either. Fundamentally a seq dog box can't really BE mis-shifted due to the combination of
dogs and sequential nature. A seq conversion onto a non-dog H box means incomplete shifts are perfectly possible (the action of disengaging one gear
comes before shifting into another gear because of the H mechanism), so the only thing it really takes out is the sideways motion of the gear lever.
Also, the distance moved by the top of the gear lever will necessarily need to be reduced when in paddle form, so the mechanical advantage will have
to be lost, meaning it'll be harder to shift physically, now using your fingers instead of your arm.
theory is a wonderful thing, reality is another
Mis shifts are possible on sequentials in my experience, but i havent used one with buttons/paddles to be fair on a dog or std box.
mis shifts are possible on dog boxes too, with a 'stick in the hand' shift
but im not interested in debating the subject, just helping OP with info and experinces ive had, will leave it to you all chaps
CNH
The info. and shared experiences are much appreciated.
Thanks everyone.
CNH
I think this would be a great addition to a "dog" box (gearkits are available for type 9) where it could actually speed up gear changes, and
with a suitable ignition/fuel cut switch could allow WOT clutchless up shifts.
However, on a synchromesh box I feel this would probably be more of a novelty than a performance mod, but that's not to say that there would be
no demand.
I had 1 of those ikeya shifters on my GTR and it was worse than awful
It was a nightmare to get working properly and even then it wasn't guaranteed to shift correctly every time.
I also found downshifting through the gears quickly to be pretty bad.
There used a fair bit by owners over on the Evo forums.
I'm now using a Hewland 6 speed. 20 times the cost of the ikeya kit with employee discount though
