I'm now road legal. Eventually. My first trip out on the trike was fun but at 70MPH it weaves a bit. Back off and it's fine. What causes weave and what should I do to stop it? Two front wheels, one rear and RWD BTW.
mine was doing the same at around 90.
figured it might be castor.?
Just a thought,
What is your rear wheel/tyre? Is it a bike type/profile, or Car type
And could it be slightly out of line?
It has a whole lot of castor angle and a fair amount of trail to try to give it self centring. Castor is good right? It has the original bike tyre on the back. I'd thought about putting a car tyre on it when the bike one wore out.
Try raising or lowering the ride height at the rear
Toe in will maybe be too small. Toe out makes for a VERY nervous car esp underbraking.
Try not to use more than 7 degrees of castor, and check carefully for bump steer, the root of many higher speed handling problems.
Good suggestions, thanks. The toe angle was set for MSVA self centring. I've changed it a touch but maybe a bit more is needed.
When I changed the castor angle, it introduced a lot of bump steer, which I removed by moving the steering rack. The beauty of an open wheeled car is
that you can see the front wheels move when bouncing on the chassis. There's no bump steer now.
I'll look out the C spanner and adjust the rear ride height. A quick test will show if it helps.
Will tyre pressures have much effect? It's hard to know what to set them to in a car that weighs less than a quarter of a tonne.
The theoretical tyre pressure is the max psi (embossed on the tyre) x the actual weight on the tyre in kgs (or lbs) / the max load of the tyre in kgs
or lbs (use the same unit as the actual weight) = a good starting point.
The max load may be embossed on the tyre or you will need to convert the load index (185 70 R13 82H - the index is the 82) to kgs.
Try here for a conversion table.
thanks Mark. For my front tyres that works out at 9 or 10 PSI. I had them at 20. I've set them at 14 PSI ready for the next time it is dry and I'll see if it makes and difference.
