Hi lads, I stripped the thread on a wheel hub, has anyone had this problem and fixed it with helicoiling the thing? I only say it as it's been suggested as a option to fix the problem. I've no idea how it's done but don't fancy changing the whole hub. Anyone???
Hell of a way to test a helicoil. ( Change the hub).
Helicoils are great for threads that don't need to be repeated dismantled i.e. anything but wheel bolts.
Convert to studs?
What he said
Tilly
+2
I would install a helicoil without hesitation, there is no limit to the number of times that the srew can be assembled/disassembled. In fact it is
considered good practice to helicoil threads in soft materials as it allows a higher torque to be applied and prevents the thread wearing out if
assembled/disassmbled frequently.
Davie
p.s. Use a quality brand such as "Recoil" and have a couple of practices as there is a technique to fitting the insert correctly.
My past experiences with helicoils do tend to make me wary of them on frequently disassembled joints, they can and do work loose if their fitment is not A1 perfect, though only when disassembling, not in operation.
Thanks lads, I like the sound of replacing with studs but it's on the rear of a escort, not quite sure how it will work?
