Hi All
The Boss [ Wife ] has a Corsa B and one of the rear springs had broke but while i was replacing [both ] springs i have noticed the chassis is getting
a little rough above one of the spring
My question is can I buy a repair panel to weld above the spring ?
Thanks for any info
Jacko
Ring a dealer!
After market Rust repair panels are a thing of the past these days except for Morris Minors, MGBs and the like.
If it so bad it needs welding is a Corsa B worth the investment in money and time ?
Erm...
www.crashrepairparts.com/parts/markid/832/vauxhall_corsa_hatchback_1996_1998_facelift/body-repair-parts-and-panels?_ts=1
Try a bodyshop affilliated with a Vauxhall dealer, very often we buy a complete chassis leg and only use the last 9 inches, and chuck the remains in
the glory bin in case it is needed at a later date.
BT is right about the corrosion repair panels, one of the few available these days is the Ford Ka fuel flap surround
go to the scrappy and cut the bit you want out of another one!
