Now that I have registered as a Trader I thought that I should say hi and give a bit of info about Carbon Copies Ltd.
Firstly the name, the "Copies" bit is not because I simply make copies of other peoples hard work but because composite parts start life as
either a "buck" or a "mould" of some sort. Parts produced from them are copies of that original buck/mould.
I have been involved with Composites for over 25 years and Motorsport for over 30 years but only struck out on my own 8 months ago forming Carbon
Copies Ltd.
Some of you may have seen some of my work on Chris Garners GT1. Most of my work is "one off" bespoke stuff but I also make a range of
"standard" parts NACA Ducts, Bonnet Scoops etc.
So if you have any requirements for Carbon or GRP parts, even if it just a bit of flat sheet please get in touch and I will try and help.
Thanks for reading,
Regards Carbon Copies Ltd
Where abouts are you based Carbonman?
Here you go
http://www.carboncopiesltd.co.uk
Nice to see new traders appearing - good luck with your venture
Thanks for the welcome. I am in the sleepy Yorkshire town of Todmorden (between Manchester and Leeds) Mind you we did make the national news over the
horse meat scandal.
[Edited on 26/3/13 by Carbonman]
U2u on its way.....
