Bit of a odd thing to do but here goes
I best explain WHY i guess , i do abit of banger racing in my spare time on oval tracks so the modification if possible does not have to be road
safe.
i normally race honda powered cars 1.6 to 2.0 and put them from injection onto carbs nice and simple so no proplems when the car starts to fold up so
not a clue about this ..
Id like to race in a non contact class also and i have been given a third generation Subaru Legacy 1998-2003 (Hence this thread) its only done 98k and
is mint apart from no reverse due to gear box trouble basicly due to track rules its fwd or rwd no AWD so is it posible to turn it to Rwd? and if so
how.
i take it you cant just remove the front shafts ...
If its not shes going the scrapyard ...
Ryan
[Edited on 1/4/13 by monck]
Weld the front diff and replace the driveshafts with stub axles?
knock the roll pins out of the front shafts at the box end and pull the CV joints apart on the hub end, pull the back of the gear box off and weld up the little diff at the back. If it takes you more than an hour I'd be surprised.
Thanks all ill have a play see how i get on
what's wrong with leaving 4x4? I did some icecross in one once, and loved the handling on the ice. It was as good as the Audi's.
Bottom of the range Impreza used to be FWD, and the drift boys manage to convert Impreza's to RWD - since its essentailly the same box I
can't see why not though the drift conversion isn't cheap.
Trying to convince the tax man its not AWD could prove to be your biggest hurdle since I'm guessing thats why you want to do it!
[Edited on 2/4/13 by chillis]
Originally posted by chillis
Bottom of the range Impreza used to be FWD, and the drift boys manage to convert Impreza's to RWD - since its essentailly the same box I can't see why not though the drift conversion isn't cheap.
I converted an Impreza to use on an autotest for a giggle. It worked ok but was a bit lairy!
Don't know if it's the same gearbox but it involves taking the centre diff out of the gearbox, emptying out all the guts, machining off the
part that drives the front and fabricating spacers to replace the gears and plates and welding everything together.
After that it's probably an hours work to convert from 4wd to rwd. The front shafts etc all stay in place.
[Edited on 2/4/13 by Brian R]
