Friend has '52 Nissan Xtrail with 2.0 petrol engine that has died. Possible cause was not checking oil
and then putting cards over the
dashboard to cover the oil/engine lamp
or possibly something let go e.g. a seal to lose oil.
AA man checked oil, poured in 3.5 l before it registered on dipstick and some of it ended on floor when engine is cranked.
So engine is pretty much dead - it turns over, won't fire, makes a knocking sound (big ends?) and sounds like there is little compression
(valves/piston rings/cam?) - so looking at cheapest way to get the car running and any advice on this is much appreciated.
Cost inc fitting a replacement engine is typically £ 1200 but engine can be bought for as low as £ 450 (ebay naturally but unknown condition other
than being said it is good by seller.)
Note being able to find a Haynes manual on this so do not know how to set up timing gear, torque head down, are head bolts re-usable etc. that kind of
stuff......
My initial thoughts are to whip off the head to take a peak inside and then take engine out to see state of bottom end.
Once an assessment is made, it is a case of pricing up the bits (shells, bearings, rinigs, pistons, gaskets, oil pump etc) and any work done (big end
skim, head skim?). My gut feeling is that is is cheaper getting a running engine than reconning it - assuminig the block is sound - which does not
bode well if oil coming out of it.
So if you have expereince of rebuilding an engine in these circumstances i.e. minimal budget what would you suggest?
Also of you know about rebuilding the Nissan engine or know of online data, that'll be appreciated.
... oh, and aprt from ebay, where else would you look for a s/h engine?
[Edited on 25/5/13 by 02GF74]
Sounds like its completely u/s to me. Easiest and cheapest way is to get and engine and simply swap them, not even worth opening it up in my experience.
I was in a similar situation last year with my Mercedes daily driver. After much deliberation I bought a 2nd hand engine from an E bay breaker with lots of positive feedback, dropped it in and was driving it the next day with the only other costs being a set of filters, oil and anti freeze.
The engine is bad case of Norwegian Blue.
A lot of recon units on ebay which suggests it is a weak unit, if the unit is a weak engine buying an unknown unit from a scrapyard is too risky
and if you go for a recon unit it would be a mistake to buy the cheapest back street unit.
If oil is poring out this suggests major damage and engine re conditioners may add a sizeable surcharge
The question has to be asked is it worth spending £1500 to £2000 fixing ?
My advise would be to tell them get the bus. If they are that incompetent with looking after a car, they shouldn't be on the road.
...ta for replies .... and as I expected here is no clear best choice.
Buying unknown engine is a risk but I am pretty sure the cost of reconditioning the existing one will be hugely expensive; e.g. a used piston + conrod
on ebay is £ 80 so 4 of them plus gasket set is looking at £ 400+ not to mention other parts so with a few more pounds, a runner could be bought.
Fitting low mileageish engine with guarantee is costing 1200 whereas 2000 will get a similar age xtrail, in better cosemtic condition but about 60k
miles above the current car) so IMO it would be more economical to sell the existing one and buy a replacement ... but she is attached to the car so
would like it fixed.
The annoying thing is that I offered to do the oil change but not got round to it (planned to get it done 2 days after the failure which is deeply
annoying) - I did check the oil less than 1 month ago but do not recall what the level was - I can only imagine it was ok else I would have topped it
up so I am wondering if something let go on the engine.
Originally posted by 02GF74
The annoying thing is that I offered to do the oil change but not got round to it (planned to get it done 2 days after the failure which is deeply annoying) - I did check the oil less than 1 month ago but do not recall what the level was - I can only imagine it was ok else I would have topped it up so I am wondering if something let go on the engine.
They could find a good lower mileage Honda HR-V of similar age for that kind of money and they can run for years without lifting the bonnet.
For low annual mileage the petrol vs diesel cost really dosen't matter much.
[Edited on 26/5/13 by britishtrident]
