I can tow my car without a B+E licence but I cant find a trailer to hire!!!
bi22le - 9/6/13 at 10:38 PM
No I am looking at a few track days further away I really dont want to drive my car, on track tyres, to the circuit if its a few hours away. Limited tools, limited comfort for the journey and no possibility of the wife and kid coming. I also have a company car with free diesel and want to use it!!
I have read this from the gov website which applies to me:
Licences held from 1 January 1997:
If you passed your driving test after 1 January 1997 and have an ordinary category B (car) licence, you can drive either:
a vehicle up to 3.5 tonnes or 3,500 kilograms (kg) Maximum Authorised Mass (MAM) towing a trailer of up to 750kg MAM (with a combined weight of up to 4,250kg in total)
OR
a trailer over 750kg MAM as long as it is no more than the unladen or ‘kerb’ weight of the towing vehicle (with a combined weight of up to 3,500kg in total)
Combined with this info from Pistonheads:
FOR B LICENCES
The Gov sites are not that good at explaining this so I have managed to find a simple way of determining whether a driver can tow something on a B only licence -
To tow over 750 kgs with a B licence you need to say NO to the following:-
Is the plated MAM of the trailer more than the UNLADEN/KERB/EMPTY weight of the towing vehicle?
Does the GVW of the towing vehicle plus the plated MAM of the trailer add up to more than 3500 kgs?
Is the ACTUAL weight of the empty trailer and its load more than the listed towing capacity?
Example of legally towing over 750 kgs with a B licence - made up figures but not that far from what can be found....
Towing vehicle -
Unladen/empty/kerb = 1500
GVW = 2000
Towing capacity = 1800
Trailer -
Unladen/empty = 800
MAM = 1500 (Perhaps originally a 2000 MAM but downplated by manufacturer so it conforms to B licence towing)
Load trailer with 700 max
Reasons it is legal for towing on a B licence -
The 1500 MAM of the trailer is not more than the 1500 unladen/empty weight of the towing vehicle
The 2000 GVW of the towing vehicle plus the 1500 MAM of the trailer is not more than 3500
The towing capacity/actual weight being towed does not exceed 1800
I have a 59 plate Focus estate with a max tow weight of 1200kg. Essentially I need a light weight trailer with a Gross weight of 1200kg or less as this is the max tow weight of my car. The trailer itself needs to weigh less than about 600kg as my car weighs around 600kg.
As if this was not hard enough I want to hire one in the Dartford area cheaply!!!
I recon there may be trailers out there but I cant find any. There is no benifit of me doing my B+E licence becasue the tow weight of my car is only 1200kg.
The questions:
1) Can I use a trailer with a larger gross weight than the tow car even if the actual weight is under the max tow weight?
2) Does the above seem correct?
3) It seems wrong that I have a modern diesel car and cant tow a light weight car on a trailer but is this the case?
Thanks for the help peeps, sorry for the long post.
Biz
olimarler - 9/6/13 at 10:58 PM
Bit of a journey GTI towing in potters bar!!
Use them a lot very good service
Oli
mark chandler - 9/6/13 at 11:07 PM
That is a long post.
Most small trailers that could carry your car will be significantly less than 600kg so I would not worry about that aspect.
Cannot help on trailer hire local to you, can you club together with someone and share a trailer and parking costs?
Or do what someone else has done on here, make a T frame and turn your car into a trailer, you could easily dismantle this and keep out the back.
Regards Mark
[Edited on 9/6/13 by mark chandler]
phelpsa - 9/6/13 at 11:48 PM
If you take the trailer test then you can tow with any trailer as long as the actual mass of the trailer is not more than the rated towing capacity.
If you do not then the maximum allowed mass of the trailer cannot be more than the unladen mass of the car.
So basically, you're limited to a trailer with a MAM of 1200kgs unless you take your trailer test, in which case you can tow any trailer as long as it isn't actually loaded above 1200kgs.
I spent ages trying to work out how I could tow legally on my B license by replating trailers and picking specific cars. Turned out the easiest way was to take the trailer test (a few hours training and the test cost £400).
number-1 - 10/6/13 at 01:32 AM
Regards Mark
Do you know where the post is on this....its something i could use myself.
spiderman - 10/6/13 at 02:08 AM
Also check your company car insurance to check you are covered to tow a trailer.
iank - 10/6/13 at 05:43 AM
Regards Mark
See this post http://www.locostbuilders.co.uk/viewthread.php?tid=171960
The government pdf posted by matt_claydon has moved to here:
http://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_200824.pdf
It's one of those issues that always seems to explode into a discussion on whether it's actually legal or not.
cliftyhanger - 10/6/13 at 05:45 AM
the trailer weight is not the actual weight, it is always the maximum weight. So if the plate says 1500kg, that is what it is (even if the trailer weighs 250kg and is empty)
daniel mason - 10/6/13 at 06:23 AM
does this mean the combined weight of the trailer and car (on the trailer) must not exceed the weight of the tow car?
but a maximum combined weight of 3500kgs?
so if a 1750kg car you could tow 1750kg combined?
if so. most trailers and kits should be ok?
Davey D - 10/6/13 at 07:20 AM
The car/trailer combo i have is perfect for this, as i have the post '97 licence.
My car is a volvo v50 with a kerb weight of 1500kg, a gross weight of 1950kg, and a maximum train weight of 3450kg. meaning i can have a trailer up 1500kg gross
My Ifor williams car trailer is gross weight of 1400kg, and an unladen weight of 400kg meaning i can put upto 1000kg on the trailer
Only problem is we are eventually looking to change to a bigger estate like a V70, but since it has a gross of around 2300kg i won't be able to legally pull my trailer until i take my trailer test as that will add upto 3700kg
Something that is reeeeally annoying is i also have a transit connect which has a higher gross weight than my volvo at 2080kg, but the maximum train weight is 2880kg, meaning that it can only bloody pull an 800kg trailer... grrrrr
mark chandler - 10/6/13 at 07:23 AM
The links above are discussing A frames and dollies, I said T frame to distinguish.
Okay, let me describe what I mean, imagine a car placed upon a a bed less trailer, so hitch affixed to 10' of 3" x 3" box which runs down the centre of the car to the balance point.
At the balance point across the cars width 5' of 3" x 3" box forming a T, this carries the braked trailer suspension units and wheels (brakes not required as total package loaded is under 750kg) just have some brackets so you can break this down.
You then just drop the car on top of this and strap down (you would probally need to positively locate so some bits of strip steel that bolt to the car to stop it floating around) the car is now a two wheel trailer, like a boat trailer really.
To accomadate sumps then just have rubber blocks packing out the car where it touches the frame, I would look at something like classic range rover bump stops.
In reality you would make this so it can break down at the join and store in the house, to fit the car assemble on the ground under the car without the wheels fitted, then jack up and bolt on the wheels, trailer board and off you go.
So box & http://www.towingandtrailers.co.uk/cgi-bin/trolleyed_public.cgi?action=showprod_TK055SU10M&category=302 add another £150 for braked, which would be my preference.
Or cut down something like this Galvanised Roller Boat Trailer With Winch Catherdral Dory Flat Bottom Speed Boat | eBay
Regards Mark
[Edited on 10/6/13 by mark chandler]
Slimy38 - 10/6/13 at 07:57 AM
Regards Mark
That seems a whole load of faff at the destination though? But I have to admit I'm not properly visualising it. For example, By the sounds of it the front of the car would be resting on the centre bar, but what would stop it from sliding off at the first corner? Or is that the strip steel you mentioned?
I don't suppose you could offer a Google image link so I could understand your idea? 'A picture paints a thousand words' and all that?
I have a feeling last time I had my bike towed they used something similar to what you're describing, but obviously a bike has a 'centre' which makes the t frame work better.
[Edited on 10/6/13 by Slimy38]
nick205 - 10/6/13 at 08:00 AM
To expand on this, for completeness, you should also check the lease company's Ts & Cs. Having used several lease companies at work, some are happy for you to fit a tow bar and tow subject to correct insurance being in place. One company we used didn't specify whether you could tow or not, but did specify that the car was not to be altered in any way from how it was delivered.
When checking the insurance, make sure you get a copy of the certificate and full Ts & Cs. My employer always provided these as a matter of course, but some don't unless you ask for them.
Finally, you may or may not know, but it's usually cheap and quick to use a public weighbridge and there's plenty of them around. Might be worth double checking your laden weights with any given trailer, just to be sure.
Neadles - 10/6/13 at 08:00 AM
I have struggled with this issue of late. The problem is the only trailer that can be used is a single axle or a twin axle that is plated to a MAM of around 1300kg because that's usually the max on a single axle. Now the problem is that most hire places have twin axle 2500kg MAM trailers so as not to limit their business opportunities. You will struggle to find a company that will meet your needs as I did, the only options are;
1. Borrow a small trailer.
2. Get some one to come with you like your parents, they can sit in the passenger seat as long as you use 'L' plates and tell your insurance company, I even know people using their grandparents with a driving license!
3. By a trailer or hire a small transporter truck.
But now the law has changed again from Jan this year which has scrapped all this MAM stuff and as long as you don't exceed 3500kg now its free rein what a bloody con!
mazie - 10/6/13 at 08:43 AM
Wayne mate you should of asked me about the trailer, I hired one from a place in old bexley, £50 a day for a twin axle braked unit. Ill try and remember what they were called. The garage said to me that I was on the limit of towing weight, us our little 1600 diesels may puff out! It's only South Wales so not a big drive mate!
loggyboy - 10/6/13 at 08:48 AM
I love that I passed 4 months before that cut off date. The back of my license is full to bursting without having done more than pass a normal test
puma931 - 10/6/13 at 08:56 AM
See page 2 in this link
http://www.locostbuilders.co.uk/viewthread.php?tid=169595&page=2
plus my pics in my archive.
Regards Mark
mark chandler - 10/6/13 at 09:01 AM
Regards Mark
It's a bit of faffing about, it does give a single cost and easy storage benefits (Bi22le parks out the front of his house with limited room), it takes a long time to collect and return a trailer so 10 minutes fitting up before towing over a whole day is not much.
To stop it floating straps would not be enough, you would need to clamp the car so front tow eye down hard to the 3" box and either side of the body, maybe flat bar or box from the the trailer wheels mountings to the rear towing eye to locate the rear, have a socket affair for the long length to plug into the axle beam with a bolt to fix in place and a strap over the top to stop it bouncing.
Workable and cheap, the ideal is a trailer so as space be comes available you could add a bed
cliftyhanger - 10/6/13 at 09:02 AM
Sort of. But geerally the car has a maximum towing weight about a third less than the maximum car weight. You need to check the specs in the car manual...
mark chandler - 10/6/13 at 09:04 AM
Pictures ^^^
cliftyhanger - 10/6/13 at 09:07 AM
That applies to people who pass their test after jan this year, I think. Not very clear:
https://www.gov.uk/towing-with-car/driving-licence-rules-and-what-you-can-tow
bi22le - 10/6/13 at 10:45 AM
After a less tired re read of this I think a few of ypu may be right in that I can actually tow upto the ford focus kerb weight.
Regardless of the MAM weight as it will be over 750kg.
So I am now thinkibg that I can use any trailer as long as trailer weight+car weight does not exceed kerb or tow weight. Which it hopefully wont.
mcerd1 - 10/6/13 at 11:19 AM
only if you changed the plate on the trailer so it quoted a MAM thet was less than the tow car
as its all worked out on the plated MAM, not whats on the trailer at that moment in time
so you need a trailer with a plate showing a MAM < the tow vehicle kerb weight
so if you want to tow over 750kg MAM you need to satisfy the following:
MAM trailer <= kerb weight of tow vehicle AND MAM trailer + MAM tow Vehicle <= 3500kg
also regardless of the type/size of trailer you can't exceed the tow vehicles braked or unbraked towing limits
i.e. it might only be a 750kg trailer, but if the car is only rated for 400kg unbraked - then the trailer must have brakes!
[Edited on 10/6/2013 by mcerd1]
scimjim - 10/6/13 at 11:28 AM
The LAW says you (bi22le) can tow a braked trailer up to the vehicle kerb weight (as long as it doesn't exceed 3500Kg) - this is MAX and with no towing experience you would be mad to go over 80% of kerb weight IMHO (particularly with a single axle trailer).
The vehicle max towing weight (which as I found out recently, is actually calculated from it's ability to pull away on an incline) is the manufacturers guide.
If you have an accident in your Focus Estate whilst towing over 1200Kg you won't be insured - end of.
Also - most insurance only covers trailers and contents third party - so if YOU crash it, your Locost (for example) won't be covered by your towing vehicles insurance.
[Edited on 10/6/13 by scimjim]
mcerd1 - 10/6/13 at 11:40 AM
have you got any links to quoted figures for this ? - I've never managed to find definate limits for my cars...
scimjim - 10/6/13 at 11:55 AM
it's in the handbooks of any modern - sites like this also show them: http://www.uktow.com/towing%20capacity.asp or http://carleasingmadesimple.com/business-car-leasing/ford/focus/towing-weight-limit/
coyoteboy - 10/6/13 at 12:06 PM
Yeah the max towing weight on the old rangerovers was quoted as over 4.5T IIRC due to the low range box.
I've almost fallen foul of this law, at no point did I think to check in case I couldn't tow something when I first passed my test (about a month after the law changed to suit the EU), so I spent a large part of my youth towing a 2T boat (nearly 28ft long on the trailer) about in a rangerover (single axle) and latterly a 2.3T boat on a double axle homebuilt trailer, and a 30ft caravan. Never had a problem, never got pulled, never even got glanced at twice on the motorway. Only in later years did I check up (forced by work) and found that I'd been towing illegally for years.
If I had crashed I've have been pretty much stuffed.
I wrote to my MP to find out why this law and testing was introduced, because the test and instruction appears to do nothing but check the absolute bare essential skills and knowledge that I'd say were a bare minimum for towing ANY trailer, let alone a large one. They do nothing to prepare someone for towing a trailer that is a significant percentage of their vehicle mass or significant length. When you see folk battering down the outside lane with a 250kg garden trailer at 90mph it does make you wonder why everyone isn't forced to take a test, no no-one and simply rely on the police pulling folk as they do now.
bi22le - 10/6/13 at 12:36 PM
What happena if the trailer is home made or has no plate to state MAM?
scimjim - 10/6/13 at 12:39 PM
as long as it was made before 29 Oct 2012 you're okay - except you don't know what it can safely carry
mcerd1 - 10/6/13 at 12:43 PM
those are far too new for me
and my old focus (98-01 zetec 1.8) says nothing in the handbook
(I think get a supplement with the overpriced towbar)
but even when I've seen qouted figures elsewhere its only ever braked limits - any ideas what the unbraked limit would be ?
scimjim - 10/6/13 at 12:51 PM
you can imagine the problem I have with a 1968 Scimitar GTE then
This Government website even offers the astounding advice that "If your VIN plate doesn’t list a train weight, you should not use your vehicle for towing."
The site I linked also shows unbraked limits: http://carleasingmadesimple.com/business-car-leasing/ford/focus/towing-capacity/
mcerd1 - 10/6/13 at 12:55 PM
tell me when you find the answer to this one
I was half thinking about using my 1970 GTE to tow with (if I ever get round to putting it on the road)
scimjim - 10/6/13 at 01:02 PM
The law says I can tow up to the kerb weight of the car (never mind what some underpaid and overworked Civil Servant has written on the Gov website).
bi22le - 10/6/13 at 01:21 PM
I am starting to think that if its over 750kg this is the rule of thumb, especially for our cars and application.
Just as an update now, I am looking into buying a trailer and if this is the case it will be up for hire at a very good LCB price. It will also be under 750kg with a 550kg car on so can tow on a later B only licence.
mazie - 10/6/13 at 02:53 PM
car trailor | eBay
rough but cheap
mark chandler - 10/6/13 at 04:35 PM
Car VIN plates did not have to declare a train weight until 1998 (I think it was) so you can do what you like with your GTE, they make very good tow cars BTW
Which is why I could tow my little car on trailer behind my XK8 as it was produced in 1997, later cars you could not.
daniel mason - 10/6/13 at 07:56 PM
this is all very confusing to me.
i passed my test in 1999
have a volvo s60 D5 which is quoted at 1552 kgs kerb weight
my trailer is a brian james twin axle (both axles braked) clubman with hydraulic tiltbed.
unladen weight 500kgs
max gross 2000kgs
fireblade race fury aprox 450kgs
am i right in thinking the unladen weight (500kg) + kit car (450kg) is ok for me to tow as i have 1552kg kerb on the volvo?
or is it the max gross at 2000kg + 450kg fury +1552kg kerb? as thats over 4000kgs and trailer is over kerb weight!
scimjim - 10/6/13 at 08:28 PM
max gross 2000kgs
trailer max gross is trailer plus load (ie the trailer weighs 500Kg, so can take a 1500Kg load).
so, I think the trailer and load are okay on the car (500+450=less than the cars kerb weight and the 1600kg max towing weight of the Volvo) and you're okay with your licence (1552 + 500+ 450 = less than 3500Kg total train weight)
daniel mason - 10/6/13 at 08:32 PM
thanks.i was worried that the 1552 kerb + the 2000 max gross would be 3552kg!
phelpsa - 10/6/13 at 08:35 PM
Unfortunately its max gross vehicle + max gross trailer so you're well over the threshold!
scimjim - 10/6/13 at 08:53 PM
bugger - he's right, it's not the weight of the load anymore, it's the plated MAM of the trailer. ie you *could* carry a car weighing 1500Kg on that trailer but it would exceed the kerb weight of the Volvo, exceed the towing limit of the Volvo and exceed your licence entitlement - therefore, you're not trusted to only carry a load that would be safe according to the car and trailer manufacturers
daniel mason - 10/6/13 at 09:32 PM
by 2kg?
scimjim - 10/6/13 at 09:34 PM
52kg? Chances are, you'll never get stopped but if you had an accident they'd check - and you'd be uninsured
daniel mason - 10/6/13 at 09:42 PM
sorry meant 52kg
but surely th gross of trailer at 2000kgs is 500kgs heavier than cars cerb anyway? even though its 500kg unladen?
phelpsa - 10/6/13 at 10:06 PM
sorry meant 52kg
Firstly, the gross trailer weight is 450kgs more than the unladen weight of the car, so fail on that one.
Secondly, gross vehicle weight is 2050kg for an S60 D5. 2050+2000 = 4050 so you fail on that one.
daniel mason - 11/6/13 at 06:03 AM
so how do i get round it then? can you get the trailers re-stamped to say 1350kg - 1400kg si it comes ibn at under 3500kgs?
scimjim - 11/6/13 at 07:28 AM
Yes - I was reading up on it last night and apparently it's becoming more popular to derate your existing trailer. You may need to go to Brian James though?
phelpsa - 11/6/13 at 08:18 AM
You can indeed. Although i'd honestly recommend just taking the test! If you've been towing a while it wont be a challenge and you should be able to find somewhere that will do a few hours training and the test in one day, then you never have to think about it again!
coyoteboy - 11/6/13 at 09:36 AM
It goes off the sum of the tyre load index values - single axle with 450kg tyres = 900Kg.
Removing/replacing plates yourself is, AFAIK, not legal and can only be done by the manufacturer.
Volvorsport - 11/6/13 at 09:41 AM
in the 1st post it says max 4250 kg , if trailer is max 750 kg ?
i know im ok since i passed in 89 , just seems to be very long winded.....
mcerd1 - 11/6/13 at 11:51 AM
just means if you passed the test between 97 and 2013 you can stick upto a 750kg MAM trailer on the back of an vehicle upto 3500kg MAM (i.e. anything you can drive on a 'B' licence)
I use this rule most of the time - my dad's big trailer is far to big to tow without a +E licence
but he also has a 750kg MAM unbraked trailer thats too big for my wee car to handle (without brakes at least) but I can tow on the back of the vans, landrovers, disco etc...
(not big enough for a for a car though )
[Edited on 12/6/2013 by mcerd1]
Volvorsport - 11/6/13 at 09:52 PM
well this guy says theres no regulation limiting the mileage using this dolly.....
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=251286585035&ssPageName=ADME:X:eRTM:GB:1123
Acc8braman - 4/9/13 at 01:47 PM
Hi,
I have b+e on my license, so what can I pull?
