http://youtu.be/BkasHdSb1nQ
:-0
Hmm me thinks that might be a write-off!
Typical M3 driver, can't drive for toffee just relies on the fancy electronics
considering the sveerity of the accident, the car stood up well and all those airbags seemed to do the trick, ceratinly the curtaion airbag stopped the drivers arms flailing through the open window
Not the kind of road you want to run out of talent on. Prat.
the car in front of him was braking into that corner more than he was, should have set alarm bells ringing....
lucky to walk away, assuming he did...
It's impressive his camera didn't get knocked off!
a bottle or two of t-cut and all will be fine
This is how he should have done it
Hopefully his insurance company will see vid and tell him to f off, and (assuming wherever he is has a similar points system to us) the law will give
him three points for every time he crossed the solid lines.
Still, according to Watchdog last night, his engine was likely to suffer cam chain failure anyway, so it saves him a "£5,000 to £10,000"
bill. Ford: fix or repair daily/Lotus: lots of trouble, usually serious and now BMW: Blow My Wallet
Simon
Its clear that the guy in front knew the road - and the BMW driver didnt . My guess is he thought the other driver had bottled it on that corner , and
over-braked........clearly not the case
That's not a squeaky bum moment.
That's a "thank god I am still breathing, i think i will goto church on sunday" moment.
That's going to need tracking.
