before 3D printing is scale up to do a full size car body shell?
http://blog.stratasys.com/2012/06/04/worlds-smallest-3d-printed-car-moving-doors-wheels/?utm_source=outbrain&utm_medium=widget&utm_campaign=St
ratasys_file&obref=ssys_list
In theory, doable now - just question of money required to produce XYZ platform big enough.
Also, the better printers have a heated envelope to ensure that the plastic layers fuse together so would just have to be "big enough".
The other problem is speed - at a typical layer thickness of 0.25mm, it will take a while to "print" out the shell.
Unless you use multiple print heads...
Edit: Thinking a bit more... 3d printers are nothing more than another tool. Just because they can do something does not necessarily mean that they
should be used for everything...but it is fun when someone thinks completely out of the box and proves a technology.
[Edited on 13/8/13 by onenastyviper]
Erm, someone already is doing that? This was posted a week or so ago;
http://www.replicadb4.com/
Although it's probably not the sort of thing you're talking about, this is more like a huge jigsaw puzzle!
The only limit I see of 3d printing is the materials available. For example, you can download a 3d picture of a teapot that can be printed out. You
can't use it though, the plastic melts at temperatures below the boiling point of water!
We discussed that link last month
The db4 printing...
http://www.locostbuilders.co.uk/viewthread.php?tid=184013
Originally posted by nick205
For many rapid prototyping and/or low volume tasks there are more established process such as SLA and SLS (even CNC machining) that offer better/different characteristics for similar machine investment/part cost (on a professional cost scale).
I'm sure I remember one that printed metal, I heard about it for printing out of manufacture parts for vintage cars. The article mentioned a scanner too so you could bring the broken part and they can recreate a fixed part in the case that a whole item wasn't even a thing
Ten years from now this will be common place, 20 years from now they'll be mass unemployment all round the world as factory's will just be
robots and printers. We'll look back at the good old days when things were actually built
[Edited on 14/8/13 by Mr Whippy]
Ten years from now this will be common place, 20 years from now they'll be mass unemployment all round the world as factory's will just be robots and printers. We'll look back at the good old days when things were actually built
I am sure you are right, it'll be exaclty like the paperless office touted 20 years ago yet moire paper is consume than ever before.![]()
A computer program could be written to be clever enough to desgin and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design and 3D print faster computers that in turn can design better 3D printers that can make faster and better computers to design![]()
Don't worry, we will be bankrupt long before then![]()
In theory, doable now - just question of money required to produce XYZ platform big enough..................... Just because they can do something does not necessarily mean that they should be used for everything...but it is fun when someone thinks completely out of the box and proves a technology.
