Seeking the collectives wisdom and experience, my 18yr old son who has been driving a classic mini now wants to buy a bmw mini,it would be the mini one and probably about 2002 to 2004 as that's what he can afford to buy and insure, so what are the problems/ faults /things to look out for on that age car?
Overheating power steering pumps is the biggest fault my wife's Mini Cooper S had in 6 years of ownership.
The runflats kill the handling and make for a VERY 'crashy' ride.
Other than that, they are quite a nice car!
Did you not see the watchdog report on the telly the other night BMW Mini steering failure and BMW not wanting to know about your problems.
Watch it on catchup tv.
As above
http://www.dailymail.co.uk/news/article-2371432/Actor-Richard-E-Grant-launches-Twitter-tirade-Mini-Cooper-daughters-steering-wheel-locks-motorway.html
They have admitted it is a fault but not published it
I did hear about the steering but didn't watch the program, i'll try to later, was it a widespread fault or isolated incidents? my wife has
had a mini clubman and now drives a countryman but they are relatively new and we've had no problems with them
Jossey thanks for the link
I had better do a bit more research
[Edited on 1/10/13 by rpm]
I know 2 people who have had them both cars have been a pain in the ass with lots of problems including the steering and also ecu failure
[Edited on 1/10/13 by big-vee-twin]
We call them the BMW Money Pit, they are not cheap to maintain.
If he really wants one it would be better to wait and get a better later model and generally less geriatric one.
[Edited on 1/10/13 by britishtrident]
Or just buy a real car
I agree with last comment big money pits and a very overated car ..
They should call them the BMW un-Tardis cos they are huge on the outside but tiny on the inside.
I had a very early "one" (bought new in 2001) and had nothing but electrical problems with it (sold it at 12 months old) - bought a new Cooper S in 2003, which I sold to a colleague at 3 years old, who sold it to another colleague at 6 years old. He still has it and apart from a full BMWSH, 3 sets of tyres (at 3, 6 & 9 years, all OE type run-flats), a fractured air con pipe (at 4 years old) an exhaust (this year) and 2 sets of pads (at 4 years and 8 years), it's been totally reliable and is still great fun to drive at 80k miles.
My daughter has the cooper, just had steering pump replaced, runflats seem to need replacing more often than normal tyres, engine oil needs checking and topping up often. The BMW mini's are nothing like the original which you could fix easily. Over complicated, expensive fad which hopefully will die out soon. Talk him into keeping the classic mini.
I've got a 51 plate cooper with a panoramic roof which is going up for sale at the weekend.
80k miles.
I only bought it over the summer for the wife while we waited for her new car to be built. Tax ran out yesterday so we're just going to sell it
as it's surplus to requirements.
She loved it - and it's a great drive (bit bumpy if i'm honest) but does put a smile on your face.
Power steering pump is a bit noisy when you're trying to park it, but it seems they're all like that.
u2u if you're interested and I can send some pictures.
Originally posted by computid
Or just buy a real car![]()
Gearboxes...... up to 54 plate they had the Midland box, built by Rover for BMW. They have weak bearings that ultimately seem to need replacing......
I went for a 54 Plate Cooper with the later Getrag box and guess what...... it's failed and I've had to press the Tiger into everyday use
whilst the dealer is sorting it out!
Otherwise, it's huge fun to drive and I'm looking forward to getting it back.
My wife has run one from 30k upto now at 60k. Other than the pas pump (BBA Reman@260 exchange) and general wear and tear items, change the tyres for 205/55 R16 can't fault it as a car in the class its in. It isn't ment to be a all round good car or indeed a direct replacment for the orginal mini. the metro was that wasn't it? It was built as a niche market car, and if viewed as such,the sales figures talk for themselfves. There is alot better newer stuff out there now, the BMW mini is knocking on 10+ years old in design. The DS3 and Fiat 500 for example. I'd go and look at it with an open mind if I was you.
Originally posted by martinq357
Gearboxes...... up to 54 plate they had the Midland box, built by Rover for BMW. They have weak bearings that ultimately seem to need replacing...... I went for a 54 Plate Cooper with the later Getrag box and guess what...... it's failed and I've had to press the Tiger into everyday use whilst the dealer is sorting it out!
we've had my wife's '05 Cooper S for about 4 years. They are good fun cars to drive with plenty of poke. Ride can be a bit harsh even
for a sevenesque owner
. Have junked all the runflats in place of some decent rubber which improves the handling no end. Few minor probs include
water leak from thermostat housing, plus an intermittent starting fault which lasted about a week or so and has disappeared a few years back. Inside
can be a bit plasticky???
Have a good check underneath as the underseal seems to be paper thin, and things like brake pipes can corrode quite quickly.....
Very much a laydees car IMHO, as the pedals are really jammed in there. Anyone with size 10's and above need not apply
[Edited on 2/10/13 by clanger]
My youngest daughter is on her 4th BMW Mini with no problems.
Works as a photographer and she gets all her lights, stepladders and photokit in OK - for a wee car she has found them to be fine.
Cheers!
Don't do it.
Designer car, none existant boot, plastic interior, expensive parts, early gearboxes unreliable, very hard ride, and very thirsty.
If you get a warranty with one which will cover the few expensive issues then go ahead.
In my opinion they do look good but I know the big faults they have are a pain.
As for the run flats mine used to do 8-9k before a change my new non run flats do more like 26k
Thanks for all the feedback, despite everything he does seem set on a mini, having read up on the psp/gearbox issues a loan from the bank of mum/dad might be needed to get a slightly newer one
I got a mini one for my daughter 2 years ago, it needed a clutch which I discounted off the car price, it's the front of the car off so an
expensive job ~£350 to have done.
She did over 20,000 miles 93,000 miles when purchased around 117,000 miles when sold, in the two years of ownership one bottom ball joint £20 and rear
exhaust box £50, thermostat £15 and rear pads and discs around £70.
The seats were always a problem, poor tilt mechanism so needed a good shove sometimes.
She loved the car, no rust worries, okay on fuel and very good fun.
Plenty of room as well if you fold the rear seats, so in my experience go for it, upon arrival change all fluids and enjoy.
Regards Mark
