Good Evening, I am after the size of the discovery 2 rear hub splines so that I can id a cv joint to fit it. As you know, these normally run a solid
half shaft. I want to use a Discovery 2 rear hub ( TAY100050), to make a custom rear upright for use on an independent suspension set up. I need to
know the outer spline details (24 spline?). That said I am also open to suggestions for other heavy duty hubs.
Think of the MNR/Haynes/Mk rear uprights and over engineer it, Thats where i'm headed.
[Edited on 2/12/13 by TPG]
