quick one for mot testers and those in the know.
steering wheel Airbag light on the beetle, ordered new clock spring but the mot ran out last week so I need an mot on it tomorrow
I'm told the yellow airbag warning light isn't an mot fail is this true ?
thanks in advance
Graeme mk
An airbag warning light IS A FAIL,
however, the ones that I have fixed, have all been seat airbags, and the connectors under the seat
wait 30 mins after car last used
pull the wireing loom plugs apart under the front seats
a quick spray of contact cleaner
put plugs back together
job done
steve
Graeme, I think you might be thinking of the engine light, that isn't a fail.
thanks in advance
Graeme mk
Airbag on light is a fail.
Airbag light not functioning isn't
Interesting as our megane passed MOT with airbag light on. Probably because its a Renault and they always have some kind of warning light on, even
when working fine.
Luckily my mrs smashed the front off in a car park so when we had it repaired we then got a new clock spring and job jobbed....
Can you help me here, what is a clock spring in an air bag?
I've heard that some people disconnect the clock spring at the column end, then insert a resistor into the plug. This fools the ECU into seeing
the airbag.
Obviously not something you want to do, or condone, but if you are desperate to get the MOT done, then rectify the problem when the correct part turns
up....
Airbag light not functioning isn't![]()
when I test a vehicle I check the function of the light,there is 2 options,fail for being lit indicating a fault,2advise for non function of light,another option is airbag removed for motorsport purposes and is therefore not required along with abs etc,any other testers read it different as we al have our opinions...
No that is definitely not the case you cannot simply take the bulb out.
See: http://www.ukmot.com/mot%20manual/index.asp?MOT_Section=Supplementary%20Restraint%20Systems%20(SRS)&MOT_Number=5.4
