Off to see a Elise 111R 190bhp this evening with a mate who's considering buying it. Other than obvious things anything else to look out for on
these?
Matt
any chassis tub damage. whilst its hugely strong, its glued and riveted and cant be cut n shut like a normal monocoque or have bits welded in. Some
relatively minor shunts can write off the tub meaning its a big job to replace. check for any rippling or signs of bigger rivets suggesting
they've been replaced.
Check if the roof leaks, check for rattles and creaks and if it doesn't do any of that, ignore it, its a duff one
i have one so can help a little
what year is it? 06 is a face lift in terms or drive by wire throttle, led rear lights, uprated pedal box, probax seats also no rear reflectors on the
later car. later cars are worth more than early ones as a rule.
its an alloy tub, check the suspension pickup points for damage there is sod all to see really, its normal for the bonding glue to be visible. body
work they stone chip easy at the front, if its above 25k and does not have any its had paint.
gearbox can be crunschy from 2nd the third when cold, uprated mounts and better fluid help along with adjusting gear cables.
engine wise its a riot, make sure it come on the second cam which is 6,200 IIRC to 8,500 rpm it needs to be warmed up otherwise there is a limiter at
around 5k, engines dont like hard track use if on sticky tires without baffle or accusump.
not sure what else to recommend, if you want to know anything further let me know, i love mine use it near enough daily only issue is its made my
seven somewhat redundant
What is the performance of these like compared to a bec? It's the car that I really fancy when I've had enough of kitcars, but worried Id not be happy enough with the speed/acceleration as I know they do the twisty bits just fine
My Standard S1 is pretty quick, 5.5 to 60mph. I think it feels quicker than it actually is though, being low and raw in terms of handelling. Id loved
to have got a 190bhp S2.... Recon you will be impressed. Totally different car to anything I've had or my mates have had, hence why I bought
mine.
Let us know the out come and post some pics if he gets it.
Rob
My mate's got a S1 with a Honda K20 engine running 220hp and from a standing start it's dead level with my blade engined (954, not a newer
one) car until about 85/90ish, where the Elise gains an aero advantage and starts pulling away.
[Edited on 2/5/15 by OliilO]
