So I'm in need of a portable jump start for (as the name suggests) jump starting a couple of cars and also to power the 12V LED strip lights in
my new garage as it doesn't have electricity and it's kind of useful to have lighting.
Obviously there are cheap as chips efforts on Ebay but if they haven't got the oomph to start the cars (including a diesel) they're not much
cop.
Machine Mart jump start packs seem to have a good reputation- anyone tried one and if so how did it fare?
I'm considering a Jump Start 900 as I'm not keen on spending ££££
Any opinions? Any other recommendations peeps?
Don't bother with the tiny ones on ebay unless someone can recommend you one specifically.
I bought one a little while ago to try it. I doubted it would really be sufficient to start a car but if it did, I thought that would be a great
thing to leave in the back of a kit car...
Sadly as expected whilst it provided plenty of power for charging various items and running minor electrics for several weeks (I just left it in my
garage which also doesn't have power) it didn't have the oomph required to jump start a car despite their claims.
Locostbuilders style, buy a decent battery, build a box with a handle and get some decent jump leads.....
Why lug around heavy/bulky batteries when you could "Locost???" something like this. And it's quick to re-charge.
https://www.youtube.com/watch?v=z3x_kYq3mHM
[Edited on 2/7/15 by Ivan]
I don't have any power in my lock up, I use a large car battery , in fact I have 2 and an inverter to power 2 x 5ft strip lights . I just take a battery home to charge although I have been thinking about a cheap solar panel since fitting a decent one on my motorhome
The 'race' solution works for me, on and off the track.
Commercial (Land Rover Diesel) battery on a race battery trolley, with Anderson plug. Will do a deep discharge for things like lights, music, 12V
tools and will also run an inverter for some time. It'll also start anything, anywhere.
Modern car batteries are "starting batteries" don't take well to being used as general purpose power battery, one deep discharge can
knacker the battery. Every time a battery is partly discharge some damage occurs and the charge capcity of the battery when recharged is reduced.
Starting batteries are only designed to be discharged to about 66 percent of their charge capacity.
For powering lights on boats, caravans and solar power storage what is known as a deep cycle battery is required.
In my shed I've got 12v lighting and fire that I've got a deep discharge battery. But when I tried to start a car with that it wouldn't provide adequate amps despite being quite big (100Ah). I'm rarely in my garage and even when I am the battery will not be overly discharged so want to go with something which predominantly will start a car but occasionally do lighting.
Also known as a leisure battery....
Originally posted by britishtrident
Modern car batteries are "starting batteries" don't take well to being used as general purpose power battery, one deep discharge can knacker the battery. Every time a battery is partly discharge some damage occurs and the charge capcity of the battery when recharged is reduced. Starting batteries are only designed to be discharged to about 66 percent of their charge capacity.
Hgv batteries are 12v and rather large......but 150 a pop...used by many in wind turbine setups
