hi
Im after two 10mm thread bolts, but not with a standard 10mm head (17mm spanner size) but more like 13mm spanner size
with a built into the head washer
I know there out there, as my old starter motor used to be held in with a pair of bolts like this
steve
Fords tend to use them for starter motor and bell housings depending on the length you need. May be able to help ?
How long? They are oem bolts so the line can use the same assembly tool around different bolts..
Ive got some here I think as I keep all the fasteners off everything I dismantle
Sounds like you're after flange bolts?
Thanks Guys, just ebayed, flange bolts and that's the animal !!
steve
One of my favourite words.... FLANGE.
Did manage to get any of the bolts if not I have 3 in my van with m10 bi hex heads I could send no probs.
I did, thanks, off ebay
steve
