What reason would someone have for covering the visible vin number on their car? This is assuming that the concealed vin number adds up with the
rest.
My thought was that someone has run the car on incorrect plates previously and didn't want the number being checked easily. Any more legitimate
reasons?
you really need to ask?
I'd have thought this was an MOT fail point anyway...
[Edited on 8/8/16 by Mr Whippy]
Enlighten me.
Enlighten me.
the point is there is no reason at all for someone to do that other an something fishy
the vin plate i.e. the one with the weights etc is meant to be in the engine bay. The chassis number could be anywhere, sometimes under the carpet on
production cars or somewhere you can see it without taking the car apart. Some modern cars have the vin number or chassis number also under the
windscreen glass so you can see it from the outside. You don't give much details of this car, does it have a plate in the engine bay? the one on
the windscreen isn't mandatory.
the vin plate i.e. the one with the weights etc is meant to be in the engine bay. The chassis number could be anywhere, sometimes under the carpet on production cars or somewhere you can see it without taking the car apart. Some modern cars have the vin number or chassis number also under the windscreen glass so you can see it from the outside. You don't give much details of this car, does it have a plate in the engine bay?
I suppose with replacement parts the chances of every windscreen perfectly lining up with a very small factory vin plate would be quite low,
especially when a replacement is fitted by hand. I'd not be concerned at all about that tbh. Especially if all the visible number match the
engine bay plate. A few cars have the vin number just riveted on to the dash top so not really a very good deterrent to ringing cars, it might
actually be a factory production tracking thing or when at dealers before a car gets a reg number
I suppose with replacement parts the chances of every windscreen perfectly lining up with a very small factory vin plate would be quite low, especially when a replacement is fitted by hand. I'd not be concerned at all about that tbh. Especially if all the visible number match the engine bay plate.
I was checking that I could still see the vin number with the new screen. He says that he's come across a lot of cars that have had them purposefully concealed with a piece of paper or marker pen over the inside of the screen. But why?
[Edited on 8-8-16 by phelpsa]
It sounds like a silly reason, however parking tickets tend to slide down the dashboard and cover the VIN.
the answer is on the web -
I see loads of cars where a pay+display ticket (old tax disc) has slipped down and covered it.
With so many cars being cloned nowadays I can understand keeping numbers "out of sight."
Take number plates for instance. Loads of people obscure the number in photo's.
Lets say you owned a car in desert camouflage colours, with dayglo orange wheels. You would definitely obscure
the plate, just in case there was another, untaxed, that had the same colour scheme, that some unscrupulous so & so
would drive about with your plates on.
No offence. Just having a laugh.
Paul G
[Edited on 8/8/16 by 907]
Another common reason is the vehicle has been repaired after an accident. More often than not the n/s airbags will punch a hole in the dash when they are deployed and a second had one is put in with the donor cars chassis number still on it.
I'd go with the cloning reason. It's easy enough to get fake plates. Copy the VIN as well and it looks like a legit, taxes, insured and MOTed motor. If they've got contacts and can get the owner's details too, they can walk away from a police check with no problem.
Yep, easy to clone if you have the time to put together a matching VIN and plates.
Covering it means that they at least can't easily get the two from one car.
I'm not sure how most things like speeding tickets stand up in court - there's no way the police can prove it wasn't a cloned car
(without image of the driver), so the evidence is worthless. Yet still it stands.
