Here's an interesting one for the LCB'ers.
I have in my possession, LEGITIMATLY, a whole bunch of second hand car key fobs.
These are mainly VW , Ford and Volvo
Before I put them into the electronic waste stream, or take out a few of the button batteries to keep my own key fob going for years, does any one
have any thoughts as to any other legitimate use or outlet for them?
I know at least the VW ones are quite valuable, and can be programmed to suit a good portion of VAG cars so will go very well on Ebay. I think Ford
fobs can also be programmed to cars, not sure about Volvo's.
[Edited on 24/8/16 by Slimy38]
I think those keys have the flip out key bit. On my renault megane I only had one keycard- the emergency manual key was held inside the keycard (it
also served to hold the battery in place). I bought a spare one and swapped the manual keys- that way if I ever locked the keycard inside the car
I'd have the keycard (which actually didn't work as such) at home with the spare key in.
Some plonker on Ebay advertised one for £1 with a text saying how they don't work if you buy them for a car other than your own and then got all
annoyed when I bought it
Originally posted by Slimy38
I know at least the VW ones are quite valuable, and can be programmed to suit a good portion of VAG cars so will go very well on Ebay. I think Ford fobs can also be programmed to cars, not sure about Volvo's.
OK Thanks guys
So is there any identifiers in the Key?
Would it be possible to identify the car it belonged to?
Modern Ford fobs can easily be programmed on the car.
Originally posted by ReMan
OK Thanks guys
