Hi! I took my van in for its mot today. I told the bloke there that I'd put a new tyre on the spare wheel and that it was in the back of the van because I couldn't fit it under the van in its normal place. he said he wouldn't even look at the spare wheel because it wasn't part of the mot test! now I've always thought that it was checked and that it had the legal requirement of tread on it. I'm sure it used to get checked. so have they changed the mots or have spare wheels never been checked please?
Spare tyre isn't part of the test. Never has been.
So the view that illegal spare tyres should be taken out before an mot is just an urban myth?
I have to admit, it's something my dad told me, and I've always assumed it to be true!
I was also under the impression the spare had to be legal if present.
Does seem stupid it doesn't get tested if fitted,as if you need to use it and it's bald what's the point of carrying it!
MOT manual states:
Tyres fitted to the road wheels only. The vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel.
quote:no they do not need to be checked
This inspection applies to tyres fitted to the road wheels only. The vehicle presenter should be informed when it is noticed that there is a defective tyre on a spare wheel.
I have a spare wheel on the back of the Seven, but the tyres are directional.
Must remember to only get punctures in the near side wheels.
Paul G
Carrying an illegal spare is an offence ,possibly under the construction and use regs , intent to use etc but as others have pointed out it is not a testable item . Another thing that isn't tested is the speedo operation
My understanding is also that the spare wheel/tyre doesn't get inspected. To me it seems daft as what would you do with the spare in the event of a puncture...fit it to the car.
Paul G
I suppose the problem is that there is no requirement for a spare, so it would be rather harsh to fail an MOT just because there was a wheel in the back that you might never intend as a spare.
I seem to remember years ago 60's - 70's, if you were nicked for a defective tyre you could also be done for an illegal spare. So if you had 4 baldies on the car and another in the boot you would get an endorsement for each tyre and the fine.
Spare tyre is not mentioned C&U except for regs relating to the use of temporary tyres (such as speed and weight of vehicle).
Speedo has been tested in MoT since 2012.
[Edited on 27-9-16 by loggyboy]
quote:it would fail if its clearly inoperative, and its backlight has to work
The speedo isn't tested it only has to be present with a largely unbroken screen . It is not tested to check it's working !
Can some people not read manuals? or do they just assume that their mate knows everything or that because they were told it once it must be true?
If someone ever corrects me i make sure i check before spouting further misleading rubbish.
From the MOT manual
Reason for Rejection
1. Speedometer not fitted.
2. Speedometer incomplete, clearly inoperative or the dial glass broken or missing.
3. The speedometer cannot be illuminated.
And there is no such thing as a law for intending to use an illegal spare tyre. That is just blatantly wrong.
Heres a list of offences... none mention a spare or intent to use.
https://www.gov.uk/penalty-points-endorsements/endorsement-codes-and-penalty-points
