I’m in the process of buying a Lotus MKVI replica chassis that is in an unbuilt/un-started condition. I’m pretty sure that this is an HGM chassis and
I was wondering if there are any other HGM owners or builders on this forum or anyone that remembers these cars. I have an original brochure that I
can try to scan/post-up.
I don’t know the precise numbers of chassis produced but I’m sure the number is very low.
Any information or history on these cars would be gratefully received.
Thanks,
George
I remember the car. I don't know much about them, but from my recollection it was a very authentic replica, down to using the same donor
components as the original (split Ford 10 front axle; Austin Metropolitan rear axle?)?
If my recollection is correct, then historic sources (specialist like Mike Brotherwood and publications like the period Sports Car and Lotus Owner
magazine) might be helpful to you?
Originally posted by Sam_68
I remember the car. I don't know much about them, but from my recollection it was a very authentic replica, down to using the same donor components as the original (split Ford 10 front axle; Austin Metropolitan rear axle?)?
If my recollection is correct, then historic sources (specialist like Mike Brotherwood and publications like the period Sports Car and Lotus Owner magazine) might be helpful to you?
Hi George
A bit more info here: https://www.locostbuilders.co.uk/viewthread.php?tid=69383
Mike
Sam, Mike,
Thank you both for your responses. I was aware of the links previously but assumed that as they were now broken they would be of no use.
I downloaded Wayback Machine, which I never knew existed and have been able to see the original HGM site pages which is an enormous help with lots of
useful info.
Thanks again.
George
