Air tight = water tight ?
Simon - 23/10/20 at 06:50 PM
I want to bleed my Beetle brakes and am thinking of modifying a double barrel foot pump.
The theory is to separate them, use one to act as a slave cylinder to push the brake pedal, the other to act as master cylinder from whichever brake I am doing and connecting them with hose pipe and using water as the fluid between the two.
What do you think?
rusty nuts - 23/10/20 at 08:26 PM
Gunsons easibleed works well for £20
Mr Whippy - 23/10/20 at 10:26 PM
What do you think?
Your nuts.
What happened to just asking someone to press the brake pedal for you or do you live on a desert island?
Simon - 23/10/20 at 11:12 PM
I like to make things difficult, don't like to ask for favours and car is at work so bit awkward to get help. I thought it was quite a good idea. Maybe I'll do the eazibleed instead
snapper - 24/10/20 at 07:40 AM
Easybleed does what you are trying to achieve with a foot pump and works.
Runs off tyre pressure
britishtrident - 24/10/20 at 01:47 PM
Just buy the right pro tool --- not expensive single man bleeding in seconds better than mucking about with an eezibleed toy Pressure Ebay link
[Edited on 24/10/20 by britishtrident]
coyoteboy - 25/10/20 at 02:08 AM
Eezibleed has worked just fine on every car I've used it on.
rusty nuts - 25/10/20 at 06:54 AM
The problem with the type shown by BT is it only comes with one”cap” , alright it is the type with the same thread as a lot of modern cars but with the straight fitting it has access is limited on a lot of cars, you have to use a cap with a right angled fitting AND most importantly it WILL NOT fit an air cooled Beetle which is why I suggested an Easibleed. The OP doesn’t say if his is a classic or modern type Beetle I know
Simon - 25/10/20 at 04:48 PM
It's a 1303 Got an eezibleed now need to find the time to do it!
rusty nuts - 25/10/20 at 06:52 PM
You need to check there is a cap to fit the reservoir in the kit ,if not modify your existing item making sure the top surface is flat and can seal . Use the spare tyre with an absolute maximum pressure of 20 PSI in fact 15PSI will work with less chance of leakage from the cap
Simon - 26/10/20 at 11:08 PM
Yeah, there are two similar sized small caps in the box and one of those does indeed fit the Beetle reservoir
