cheap AC compressor replacement ?
mcerd1 - 19/9/22 at 06:45 PM
My tin-tops had a bit of a rattle for a while thats been getting gradually worse - I was hoping it'd just be a heat shield, but no luck
when I finally got a proper chance to get underneath it turns out its the AC compressor - rattling like a bag of spanners
so while I've 'solved' the issue for now (by taking the belt off) I'd rather sort it properly - but I'm finding prices anywhere from £150 to over £400
or I seem to be able to get scrapyard units at £25-£40 (its a 1.8 duratec in a C-max)
AC is one area I've never dealt with before now and I don't want to be messing about with unreliable aftermarket rubbish parts
(I've got my brother offering to do the empty / refill at his work for free - but I won't get more than a couple of go's at it)
and the car isn't worth enough to spend top dollar on new genuine parts...
so any recommendations on brands / where to buy / any other tips & tricks?
mark chandler - 19/9/22 at 09:04 PM
I dropped a second hand (factory original) one on my car years ago and it’s been fine, I did drain all the old oil out the system including flushing it through, same for the new/old pump and it’s been fine - it will need a new dryer.
If it’s clanking you will need to do this whatever pump you put in.
ReMan - 20/9/22 at 12:01 AM
Its often the clutch that rattles not the pump itself
Assuming its still working. And its likely you can remove, check, lube, replace this without disconnecting the gas side
coyoteboy - 20/9/22 at 11:32 AM
This. It was my plan until I left it so long the pump grenades from the heat input too.
nick205 - 20/9/22 at 02:53 PM
Tin top AC's a bugger. Great when it's working, but always seems to be £££ to fix when it develops a fault. Plus having to pay people with the right kit and skills to empty/re-charge it with gas.
On my last car (VW Passat) it thankfully never developed a fault. A re-gas every 5-6 years seemed to keep it running good a icy cold.
I'd be hesitant to fit a scrapyard sourced AC unit for my own distrust of it's longevity and potentially having to payout again to re-fix.
