Finally getting my BBS RX2 wheels refurbed for my tintop.
They are two piece split - the outer rim is continuous so there is no issue with air leaking at a split join.
Question is - when I reassemble them should I use some kind of joining compound between the centre and the rim? Some videos on YouTube I see are
just assembled dry. Can see pros and cons for dry and sealed.. what are your thoughts?
I did with mine. I used the best clear RTV I could find. I had one leaker though and re-did it with grey polyurethane which solved the issue.
I just dug-out my old blog post here which perhaps isn't as helpful as I recall: https://timsmnr.blogspot.com/2013/05/because-youre-wurth-it.html
If the outer rim is continuous, what's the point? What would the sealant be sealing?
Could prevent corrosion in the joint caused by water ingress.
Correct me if I'm misunderstanding...
If the outer rim is continuous then how is it a split rim?
Surely what you have is a rim with the ability to fit different hub to rim sections (spokes)?
I can see that would allow you to alter the appearance and offset, but not the rim width.
If that's correct then I'm not sure what the sealant would be sealing.
Threadlock perhaps on the threaded fixings, but only in accordance with the wheel manufacturers instructions.
Thanks for the reply.
Yes, they call it a split rim but I supposed technically that is not what they are... just two piece wheels.
Sealing would keep moisture out and prevent corrosion perhaps, but otherwise, no purpose.
Just dropped them at the powder coaters -I split the wheels 16 years ago and they have been sat in my shed pending refurb since then
Last time I had to take apart a two piece wheel which had been RTVd together I nearly destroyed it.
I would want a dry joint in there, not sure I would even want powder coat or paint. The 2 surfaces need to be tigh together, with no chance to
fret.
If you really want to seal it, i would be finding a VERY thin product. Wellseal may work.
Going slightly off topic, what problem do split rims solve? Why would you choose them over regular wheels?
They solve one major problem, which is the ability to quickly and easily change offset without buying a whole new set of wheels.
