Sat waiting for keyhole knee surgery to sort out a carteledge tear. Keen to have it done and get back running and cycling, but not looking forward to
it. Apprehensive of the general anaesthetic too, never been put under before.
Mainly though I'm nil by mouth and gagging for coffee
Good luck mate!
I did something to my knee snowboarding last year, and it hasn't been right since. Took nearly 2 months to get an appointment with a physio, but
she was brilliant.
However, if I don't do the exercises 3 times a day, within a couple of days I'm knackered again
Just think of it like just a quick tidy up of a frilly GRP bodywork edge, nothing like a full engine swap eh
Good luck!
Enjoy the anaesthetic. When I was doing anaesthetics a certain local FC football player said as he was going under "wow, this is better than
drugzzzzzzzzzzzzzzzzz" before falling asleep. I think the problem is people think of gas induction for anaesthesia (too many TV programs showing
anaesthetics leaning forwards with gas masks) whereas I've only ever seen profolol injection which I must say (having had it twice now) really
isn't that bad.
Yes the NBM bit is a bit trying.
I've had a smilar keyhole operation on my knee after I tore the cartilage and my knee would lock prior to the op.
All good now several years on.
Good luck.
Ian
Good luck Nick,
I had a cartledge op about 14 years ago, while playing football i tore my cartledge, 1st they went in with the camera, then they opened my knee up to
remove some, ended up being under GA for about 4 hours, being 21 at the time helped though, within a day or 2 of leaving hospital i was playing
football again, much to the doctors dismay
A little game for you.
When they put yo under (which is nothing to worry about. Just like falling asleep when you have had a few too many!), but often they say ' now
count to 10'. If you can get to 3 or 4 you are doing well. I have had quite a few ops now and am sure i have built up a tolerance to GA as i
got to 7 once i seem to remember. Helps if you have an independent adjudicator to verify.
Best of luck Nick with the op. As above try not to get too worried about going under, see how many you can count back I bet it won't be far. All the best for a speedy recovery.
When they put yo under (which is nothing to worry about. Just like falling asleep when you have had a few too many!), but often they say ' now count to 10'. If you can get to 3 or 4 you are doing well. I have had quite a few ops now and am sure i have built up a tolerance to GA as i got to 7 once i seem to remember. Helps if you have an independent adjudicator to verify.
I have never managed to get past 3,
Question. My elbow locks up a lot especially on extension and is generally really painful. I can't full extend it either and there are grissly
lumps on the inside near my torso. Do you think this is cartiledge damage? Can anything be done?
Question. My elbow locks up a lot especially on extension and is generally really painful. I can't full extend it either and there are grissly lumps on the inside near my torso. Do you think this is cartiledge damage? Can anything be done?
Had my left knee done about 8 years ago. Only bit of advice I will give is go to the gym and build up leg strength will help with the recover at the 3
- 6 month period. Also it took ages before i could Kneel on it - believe this is normal.
All the best.
Best wishes Nick, do hope all goes well. My thoughts are with you.
best regards
John
Good luck with it all. I have now had my right shoulder operated on twice in the last 15 years. During the last Op the surgeon found an old stitch
left over from previous op 14 years ago...hence the leverage effect and pop goes the shoulder
So far so good but only been 4 months or so but I'm left with a lot less movement and a fear of over reaching as the surgeon stated no more can
be done if I pop it again. Joint is ok it's all the stringy bits
general anasthetic is pretty awesome lol, you hear some pretty cool stuff if you try to stay awake. i heard some prety cool sounds, like springs
boinging about, wish i could have recorded it for some tunes
not sure if 'trying to stay awake' is a good idea, but thats how i did it. can't remember what number i got to though.
Good luck with the Op.
I had a general 4 weeks ago for an ankle problem (still off work in a removable cast) and it was fine.
They put a Canular (spelling??) in the back of my hand and apart for a cold sensation up my arm, I can't remember a thing! When I came round it
felt like the best sleep I'd ever had with no after effects..... Unlike a previous general where I upchucked the first thing I ate
(but I
think that was down to dehydration).
Just come round! Dazed and a bit gippy.
Out like a light, cold sensation and got 3, then gone.
didn't want to say before you went under but I get as sick as a dog any time I have a general
didn't want to say before you went under but I get as sick as a dog any time I have a general![]()
Originally posted by hising
As an Orthopaedic surgeon (In Sweden) <snip>
To think that your fellow locostbuilder could give you an answer on this forum is kind of fun, I think.
I'm frankly horrified that you consider the possiblity that we might *not* know a solution!![]()
This is Locostbuilders- we pride ourselves on solving *any* question!
You've pretty much failed the first test of LB, if you'd been here longer I think we'd have to consider this worthy of a life ban.
Liam,
Start with a Stanley (use celly thinners to clean the blade- last thing you want is an infection!). Open up the joint. You may need a mirror wedged in the vice to help you see all round the elbow.
Next, take your grinder with a fresh flap wheel and smooth off any nasty lumps you find.
Rinse out any loose bits with fresh (obviously!) tap water.
Stitch it up (get some pink cotton from the missus- you don't want to clash!). In you can't find a needle then use a stapler.
If there's any bleeding still then use your blow torch or soldering iron to cauterise it.
Job done!
Hope that helps!!
James
Don't bother stitching, just use gaffer tape
It's all about the right tools for the job - superglue
