Hi guys,
In my Fathers infinate wisdom, it was a good idea to take the flywheel side crankseal off to get a trust bearing in the end of the crank?? Stupidly I
listened to him and now i think i would be better off replacing it as a precation?
Question is, do you chaps know where to get one, its a blacktop 1.8 from a mondeo if that helps? I found these guys
Click
But delivery seems expencive and im not sure between the difference of FR and RR crank seals?
Cheers guys!
Jas
Burton power for anything Ford or even Ford them selfs.
I would ring them re post if its over the top.
[Edited on 7/7/10 by big_wasa]
i can sort you one, email me at work with what you want a proper genuine one aswell
alastair.smith@fordretail.com
Ford dealers carry them iirc and theyr not that expensive. Or burton power but the post will be about 4 quid on a 5 quid seal.
Motor factors stock seals aswell.
I have to say it. What was your dad on? Youd never fit a thrust bearing through a seal hole?
[Edited on 7/7/10 by Danozeman]
IIRC one of the seals was 'kin expensive when I bought them from my local Ford stealership and Burtons was waaay cheaper at that time
Can't remember whether it was flywheel or front pulley end that they wanted £50 for though off hand
The trade off is that some of the other stuff I got from the main dealers was way cheaper than anywhere else
It pays to ask and shop around IMHO
Regards
Rob
cheers guys, yeah seal is about 50 quid from ford
Another vote for Burton Power
