I'm looking for a large silencer to go on the side of my car, it must be 3" bore and get my turbo ZX10R exhaust noise down to a volume that
will pass trackday noise limits.
Anybody have any suggestions or reccomendations?
Probs best to talk to mark and Col as they have plenty of experience with ZX10's in Mac1's. Have you tried talking to BigRich? He had quite
a novel way of exhausting the gasses on his car.
I guess your issue might be more induction related once you get the exhaust note under control. Should be a few on here who have had to quieten down
there turbo induction noises. There was a guy in the Newcastle area, member of NE7ers, who fitted a turbo to his MK. Geoff???? Guinness will remember
him.
Originally posted by DarrenW
Probs best to talk to mark and Col as they have plenty of experience with ZX10's in Mac1's. Have you tried talking to BigRich? He had quite a novel way of exhausting the gasses on his car.
I guess your issue might be more induction related once you get the exhaust note under control. Should be a few on here who have had to quieten down there turbo induction noises. There was a guy in the Newcastle area, member of NE7ers, who fitted a turbo to his MK. Geoff???? Guinness will remember him.
How noisy is the exhaust at the moment? What are you trying to get it down to?
looks nice and neat but i guess there is little space to fitter a larger / longer exhaust can if you are trying to contain it under the bonnet. or you
pretty much fixed in terms of diameter and length? A pic under the bonnet might help others to suggest a solution.
What is your current can packed with? Obviously i dont know if its new, fairly new or well used etc but i have heard of people needing to repack
exhausts after some use, or even repack them to get the noise down. might be worth seeing if there is a way to mod yours to make it repackable so you
can play around with different pack densities.
there used to be a lad in Tynemouth that was good at welding stainless and alloys - Deano. Or failing that there must be a few tuning places that make
exhausts and could perhaps mod yours to be repackable.
Are the BEC running turbo's that noisy?
Running the sr20det setup with cone filter with short usual kit car style exhaust setup - 3" downpipe to old 2.5" backbox from the original
zetec lump and its not loud at all
I am going to put a 3" backbox on over the winter but while its still running 220ish bhp there is no real restriction
A good friend Dave Hardwick is currently finishing a 3" exhaust for the VX220 turbo and also using the backbox for the audi tfsi (s3) conversion
I am doing. Fantastic quality of material and workmanship
I plan to use the same setup box but obviously sized for the la gold pro comp
Sure he would make one for you if required, very reasonable for the quality of work but its not going to be free
Picturs of the VX220 turbo system in development - Packing is from Thermal Velocity.
http://www.davehardwick.co.uk/
DG
[Edited on 20/6/13 by Duncan Grier]
looks nice and neat but i guess there is little space to fitter a larger / longer exhaust can if you are trying to contain it under the bonnet. or you pretty much fixed in terms of diameter and length? A pic under the bonnet might help others to suggest a solution.
What is your current can packed with? Obviously i dont know if its new, fairly new or well used etc but i have heard of people needing to repack exhausts after some use, or even repack them to get the noise down. might be worth seeing if there is a way to mod yours to make it repackable so you can play around with different pack densities.
there used to be a lad in Tynemouth that was good at welding stainless and alloys - Deano. Or failing that there must be a few tuning places that make exhausts and could perhaps mod yours to be repackable.
The VX220 turbo backbox is 7inch x 28inch - the length is easy to change but the & inch change means making more tooling. Of course can be done
but means more work
Spoke to Dave just and if it helps your more than welcome to pop in and fit a vx220 box on to check noise levels. Give him a call and mention me -
Duncan and maybe he can help
All the best
DG
Thanks for the research and advice Duncan, unfortunately Dave is 180 miles away from me, a little to far to pop in.
The VX220 box sounds like a great size, that must have a good influence on noise levels.
Understood its too far and just an offer really if you wanted a long day out
It has been built to really address the noise levels on the vx220 high powered turbo's on track now they are getting more and more....well its an
issue
It could also be made longer if you have the space which would only further reduce the noise levels. Have some data on levels on his 400bhp garrett
powered vxt with decat etc but of course different setup
A lot of research and development also in the packing material, especially on the high powered supercharged vx220 have an issue burning / eating it
all and spitting it out. This stuff is not the cheapest but does what its supposed to
If you know the dimensions / mounting points etc, no reason Dave could not make and post. Prob even polish if thats your prefered
Glad I could help
DG
