bought a gearbox mount/crossmember from SHP, but it doesn't fit
they race with a rocket box, i'm using type 9, so it was expected I suppose. it doesn't quite line up.. not far out right enough
Will need to make my own cross member i think. it just so happens the type 9 box mount passed directly through the centre of the cross member, so
should be pretty starightforward. i hope.
if no one's got one to sell me, photos will be good enough for now
Think Ive got one in garage, Ill have a look and let you know
cheers
nice one!
I got mine from Westfield at a surprisingly reasonable price!
Caber
what if i was to use a piece of threded studding, with a peice of nylon in the middle?
on a cotton reel bush for example, does the threaded part run all the way through, or are they seperate in the middle?
or where could i get a cotton reel bush with the same thread for the threaded hole on the gearbox?
