Author: Subject: Can someone check my maths?
turbodisplay
posted on 20/12/09 at 02:24 PM Reply With Quote
Assuming no friction and a constant hp engine, a 1000kg car takes :
30 hp to go from 0 - 15mph in a second.
482 hp to go from 0 - 60mph in a second.
I think I`m right just would like to get a second opinion.
Darren
[Edited on 20/12/09 by turbodisplay]
matt_claydon
posted on 20/12/09 at 03:17 PM Reply With Quote
Kinetic energy = 0.5*m*v^2
60 mph = 26.8 m/s
Therefore KE at 60 mph is:
0.5 * 1000 * 26.8 * 26.8 = 359120 joules
To get that much KE in one second would therefore require a power input of 359120 W, i.e. about 360 kW.
360 kW = ~483 hp.
I assume you did the 15 mph calc the same way. Neglecting friction is rather a big assumption though
[Edited on 20/12/09 by matt_claydon]
clairetoo
posted on 20/12/09 at 03:18 PM Reply With Quote
Not sure about your maths , but my 232 bhp drag-bike would go from 0 - 60 in .97 sec - but it only weighed 270 kg (with me sat on it)
So I guess double the power and 4x the weight done quite add up ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
turbodisplay
posted on 20/12/09 at 03:52 PM Reply With Quote
Thanks matt, saved my sanity! I used the same calc, but I was having problems reversing the calculation, so wanted to check.
I agree that ignoring friction is very wrong, I will adddress that!
Claire how much did you rev the engine, you can get huge increase in power by storing energy in the flywheel, so the inital hp could be in excess of 1000hp!
Darren
clairetoo
posted on 20/12/09 at 04:02 PM Reply With Quote
Darren
Bikes dont have a flywheel
In fact , it had a lightened crank and clutch as well as a taller primary drive (to slow down the clutch and gearbox) - it left the line at 8400 , and hit 12800 before hitting second gear (at about 62 mph)
Claire xx
turbodisplay
posted on 20/12/09 at 04:44 PM Reply With Quote
As you can see I`m not a bec person!
Obviously there is some rotating mas though.
Thinking about it 4 times less mass, half the power means 0.5 s, with friction 1s sounds right.
Darren
Angel Acevedo
posted on 21/12/09 at 03:05 AM Reply With Quote
Answers wrong!!!
No friction=No traction.
Spinning on 2 axis!!!
engine wise and wheel wise....
Ninehigh
posted on 23/12/09 at 12:45 AM Reply With Quote
True but how would he factor in the friction? For starters what's the drag coefficiency of the vehicle, and then what's the drag of the tyres?
Then is there anything else? Winds, crosswinds.. No doubt there are far too many variables.
