Author: Subject: removing rusted/seized allen head bolts from exhaust can
MK9R
posted on 28/1/10 at 10:55 AM Reply With Quote
I need to repack my can, but the 4 allen head bolts holding the end plate on are seized solid, have soaked in wd40 for a few days and tried heating it, but they just won't budge. any other suggestions?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MikeR
posted on 28/1/10 at 11:00 AM Reply With Quote
plus gas is more effective than wd40 - available (When i last got some) from halfords.
Have you tried shocking them?
What about tightening them a little?
What about heating lots and then cooling rapidly (although this may have other side effects on the rest of the can)
Mr Angry Grinder and Mr Drill?
MK9R
posted on 28/1/10 at 11:01 AM Reply With Quote
Have tried hitting with a hammer ontop, no help!
Mr Angry Grinder and Mr Drill will be coming out to play tomorrow if all else fails
Cheers Austen
RGB car number 9
www.trackace.co.uk
tomgregory2000
posted on 28/1/10 at 11:08 AM Reply With Quote
fire is your best friend
iscmatt
Contributor
Posts 1929
Registered 30/3/06
Location York
Member Is Offline
Photo Archive Go!
Building: - BUILT - 2.0 pinto indy, Kent Cam, zzr1100 carbs
posted on 28/1/10 at 11:15 AM Reply With Quote
not if your on an iceburg in the Arctic !
tomgregory2000
posted on 28/1/10 at 12:57 PM Reply With Quote
but how would you cook the fish?
Canada EH!
posted on 28/1/10 at 03:42 PM Reply With Quote
Old trick used for years to remove rusted bolts from guard rails. Heat the bolt head to cherry red then douse in cold water, or as we do in winter, throw it in the snow (need 6" snow).
