belgian2b
posted on 18/2/10 at 09:13 PM |
citroen berlingo electrics
Hello,
this not a locost problem, but i hope to fin some good advice here.
My wife drives a citroen berlingo 1.4 .
Since yesterday, the dashboard does not work anymore.
No lights, no tacho, no speedometer etc...
Everything works fine on the car , but the dashboard is dead.
I have checked the fuses and they are good.
I disassembled the plastic around the dashboard , but i can't findany loose wire .
I tried disconnecting the battery and reconnecting , but still nothing.
So any ideas ??
Gerardo
mad4x4
posted on 18/2/10 at 09:20 PM |
Check and see if there is a fuse under the bonnet my zx had a second fuse box.
Sounds like the main feed of the igintion to the dash is gone =
Definately a fuse somewhere/.
Scot's do it better in Kilts.
blakep82
posted on 19/2/10 at 12:33 AM |
hopefully, but what about a earth in the intrument cluster, or a main power feed wire broke inside? or the plug loose?
________________________
