omega0684
| posted on 23/3/10 at 05:52 PM |
brake fluid warning light on remote reservoirs
evening all,
i am looking to transfer my single brake fluid reservoir, which is currently mounted to the scuttle, to two separate individual reservoirs to allow
for an interchangable scuttle system [one with screen and one without - don't ask for details, its a long story]
i have been looking at these wilwood master cylinders, 0.75 for front calipers and 0.625 for rear
http://www.rallydesign.co.uk/popup_image.php?pID=4053
i have a question regarding the low level brake fluid warning light.
Do you have to have one to pass MOT? if you do, can anyone offer up idea's on how you would install one with these cylinder reservoirs?
cheers
prawnabie
| posted on 23/3/10 at 05:55 PM |
Im sure you just have to be able to show the light is working.
doddy
| posted on 23/3/10 at 05:56 PM |
you can use this
http://www.cbsonline.co.uk/brake-fluid-reservoir-cap-flcap-129-p.asp
omega0684
| posted on 23/3/10 at 05:57 PM |
quote: Originally posted by doddy
you can use this
i have one of those on my current reservoir but doubt it will fit the wilwood ones even if it was separated
[Edited on 23/3/10 by omega0684]
doddy
| posted on 23/3/10 at 06:08 PM |
they fit on my girlin res pots
| posted on 23/3/10 at 06:36 PM |
Yup, they sure do Same on mine. they're standard Ford parts btw, any brake fluid level sensor of an old Ford will fit...
bigfoot4616
| posted on 23/3/10 at 06:52 PM |
mine used to pass its MOT without one so i don't think it is needed, although probably a good idea to have one if you can
[Edited on 23/3/10 by bigfoot4616]
britishtrident
| posted on 23/3/10 at 07:31 PM |
Save a lot of money
Clutch mastercylinder for series 3 Landrover 0.75" bore
http://www.paddockspares.com/pp/SERIES/Clutch/Clutch_master_cylinder-S111.html
http://www.landroverspares.co.uk/product.html?cpdID=468
[/I]
adithorp
| posted on 23/3/10 at 08:15 PM |
I think you might have that ^^^ the wrong way around.
I've never seen the fliud level sensor checked at MOT.
adrian
http://jpsc.org.uk/forum/
cd.thomson
| posted on 24/3/10 at 09:08 AM |
Yes those are the sizes dax supply as standard with their pedal boxes. 0.625 is the m/c for the front circuit.
adrian
Craig
