speedyxjs
| posted on 13/5/10 at 08:38 AM |
Big brake fittings
I brought a new slave cylinder to replace my leaking one. As the cheapest jaguar one was 40 odd quid, i found a landrover one for 11 that looked like
it would fit and it did. the problem i now have is that the brake fittings are different and all the local motor factors dont have any the right
size.
A normal M10 bolt fits fine but i have 10x1mm fittings in the garage but seem slightly too small.
Does anyone know what size it might be and where i might get some to fit?
blakep82
| posted on 13/5/10 at 09:00 AM |
ooh what land rover is it off of? there's a size of imperial fitting which is very nearly M10, but not quite. 3/8" unf i think it is?
M10x1 fittings go all the way in, but rattle around a little.
________________________
flak monkey
| posted on 13/5/10 at 09:11 AM |
3/8UNF is the other common size yes.
Sera
http://www.motosera.com
daviep
| posted on 13/5/10 at 10:03 AM |
3/8" unf is slightly smaller than 10mm so a 10mm will not screw into a 3/8" hole but a 3/8" fitting will be loose in a 10mm hole.
So either you've tried a 3/8" fitting in a 10mm port or you've tried a 10mm fitting in a hole which is bigger than 10mm.
Hope this helps
Davie
flak monkey
| posted on 13/5/10 at 10:04 AM |
Other than that the next sizes up are M12x1 and 7/16UNF
Sera
speedyxjs
| posted on 13/5/10 at 10:07 AM |
I brought a 3/8 but that is too loose so it must be 7/16. cheers guys
