peter bland
posted on 23/7/10 at 05:18 PM |
electric reverse light
Just wired up my reverse light,its not very bright when i press my button. Has anybody the same problem. The light is wired to the stater motor
solinoid on the relay. cheers
dazzx10r
posted on 23/7/10 at 06:25 PM |
I'm wiring mine to a switch on the dash that is only powered when the engine is in neutral, with a secondary push button for the reverse.
gavin174
posted on 23/7/10 at 06:28 PM |
have you checked you havent fitted a 24v bulb by mistake..
could be a nice easy fix.
peter bland
posted on 23/7/10 at 07:09 PM |
im not sure what bulb is fitted but i will cheak , cheers
jack_t
posted on 23/7/10 at 07:58 PM |
where abouts in the north east are you ?
what car you building
I'm in stockton
posted on 23/7/10 at 08:09 PM |
Is the light any brighter if you connect it to another live ? If so then wiring a relay into the starter solonoid feed wire may help?
peter bland
posted on 23/7/10 at 08:41 PM |
jack-t u2u
