r1_pete
| posted on 17/8/10 at 10:59 AM |
Alumnium casting deterioration
The alloy thermostat housing on a manifold I'm working on has corroded in places, I've cleaned all the white powder away and lightly
waxoyled it, but is there anything I can do to prevent further deterioration?
tegwin
| posted on 17/8/10 at 11:30 AM |
Can you have it shot blasted and then annodiesed?
www.verticalhorizonsmedia.tv
alistairolsen
| posted on 17/8/10 at 11:34 AM |
normally the corrosion is on the pipe stub where the hose has been weeping hot coolant onto it? Light bit if sealant when you fit the hose
My Build Thread
britishtrident
| posted on 17/8/10 at 12:13 PM |
Make sure you use the correct type of anti-freeze coolant at a high enough concentration.
On a fully cleaned out system I would use an OAT long life coolant at 50% concentration.
[/I]
