gavin174
| posted on 10/10/10 at 10:12 AM |
degreaser tank
stupid question no.1..
I have bought a 40 gallon degreaser tank.
similar to this one..
http://cgi.ebay.co.uk/NEW-150-LITRE-40-GALLON-PARTS-WASHER-TANK-CLEANER-/130349328541?pt=LH_DefaultDomain_3&hash=item1e596ce89d
do i need 40 gallons of degreaser or will that fill it to the top..
cheers Gavin
wilkingj
| posted on 10/10/10 at 10:28 AM |
Dont fill it to the top! It will splash everywhere, and cover you as well.
Also if you put a large item or two in there it will overflow!
Also consider a full face splashguard, and a good supply of stout rubber gloves that wont disolve in oil / solvents.
Choose your degreaser fluid with care, it needs to do the job, and you need to remain safe.
Solvents can be absorbed by the skin and attack your nervous system. So do it right, regardless of the money... Health is a life time issue. (I know
from bitter experience)
Good tool though, I have the next size down and its a good bit of kit.
Best Regards
Geoff
http://www.v8viento.co.uk
gavin174
| posted on 10/10/10 at 10:31 AM |
would 20 gallon be enough..
I am sure you only half fill them..
what fluid would you recommend and wheres the best place to get it from.
thanks
Mark Allanson
| posted on 10/10/10 at 10:46 AM |
All the ones I have used, you don't fill at all, you fill a tank underneath and the pump takes the cleaner upto the spray tap and then it flows
back into the pump tank via a filter trap.
trextr7monkey
| posted on 10/10/10 at 01:48 PM |
Hi ,we had one similar bought from a westfield guy who had never used it - if there's a shelf inside the fluid level wants to be below that-,
there might be a line stamped onto tank.
Beware of the smell - ours came half full of some sort of paraffin/jizer derivative and after a few days the whole garage had the sweet sickly smell
that really switches women into nagging mode
I think machine mart advertise some water based parts cleaner but I've never used it - the eco friendly versions never seem to be as good as
the stuff "made in the days when people didn't give a damn about anything but getting the job done"
atb
Mike,
interestedparty
| posted on 10/10/10 at 01:55 PM |
Parrafin is pretty good, doesn't smell too bad, you can buy it from ironmongers who sell it as fuel for greenhouse heaters etc.
Obviously it's flammable, but only if you actually light it deliberately, and naked flames in a workshop are problematic anyway.
As some day it may happen that a victim must be found,
I've got a little list-- I've got a little list
Of society offenders who might well be underground,
And who never would be missed-- who never would be missed!
