907
| posted on 25/10/10 at 07:39 AM |
Garage heating again. Thermostat ?
Hi All.
I have a Dimplex electric wall mounted heater that I would like to run through a room thermostat.
At the moment on a low setting it just switches on and off repeatedly regardless of the temperature in the garage
and on a higher setting it stays on all the time.
I would like it to stay on, but switch off if the temperature gets above a pre set level, (say 55F)
with the t/stat mounted on the opposite wall to the heater.
Best thing so far that I've seen is this on ebay for £22. (switches 3kw)
Image deleted by owner
Is there a better way?
Any c/h fitters out there with any s/h stuff or advice?
Any help would be much appreciated.
Paul G
[Edited on 26/10/10 by 907]
splitrivet
| posted on 25/10/10 at 09:00 AM |
Trouble is a CH Stat will only handle control current. So by the time you've bought the stat and the programmer if you want to time the
operation then a suitable relay and faffed about you might as well buy the Ebay jobbie.
Bob
907
| posted on 26/10/10 at 07:17 AM |
Thanks for the advice Bob.
In the absence of any other ideas I've been to the bay and bought the one in the pic.
Paul G
