Tris
posted on 4/3/11 at 07:13 PM |
Waterproof decking / sheet material - where ?
Hi all,
On my trailer it's currently open down the centreline, and I would like to block it off. It's about a 10ft by 3ft hole.
First thought was just to use some 18mm sheet ply, but then that's not excatly going to last long. I then remembered you can get some waterproof
decking material that's used on boats and a like.
Anyone got any ideas where I can get some or any other low-cost alternatives ?
Tris
MakeEverything
posted on 4/3/11 at 07:28 PM |
It should last if you use marine or pressure treated ply.
Kindest Regards,
Richard.
tul214
posted on 4/3/11 at 07:57 PM |
Search for Phenolic ply
1.6 Raw Super6 sold
balidey
posted on 4/3/11 at 08:03 PM |
its got loads of trade names, but often goes under the Wisa names, so Wisadeck, Hexadeck etc etc
Which as said above it basically a phenolic coated patterned ply
Dutch bears have terrible skin due to their clogged paws
HowardB
posted on 4/3/11 at 08:49 PM |
all my trailers have had 19mm WBP ply, it's an exterior grade ply, and once it's had a coat of paint will last ages. Both trailers live
outside and one is over 10yrs old with only small amounts of degradation on the ply.
hth
Howard
stevegough
posted on 4/3/11 at 09:21 PM |
How about that bit of curvy white plastic that is currently covering it in your avatar? It would need a bit of flattening out first......
Or...sensible head on now.....what about some ally sheet?? - do you want to be able to walk on it, though?
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
