se7en
| posted on 8/4/11 at 10:33 PM |
More proof of Kwik-Fit uselessness - if needed
Son-in-laws Astra needed MOT and I told him not to take it to Kwik-Fit like he did last year.
Kwik-Fit serviced the car and they told him he needed new tyres, a headlamp bulb and new brake pads, all of which I doubt were needed. They passed it
after fitting the new parts.
This year he took the Astra to Xpress MOT and it failed.
The fail list was for three things, two tyres fitted wrong directionally, headlamp beam too low, oil reservoir too full.
The Son-in-law doesn't do many miles and he has not had a puncture in years so the tyres that Kwik-Fit fitted last year were mounted wrong
directionally.
The headlamp that was too low was the one Kwik-Fit put the new bulb in for last MOT.
The reservoir was no doubt topped up by, guess who, Kwik-Fit.
My Son-in-law now knows why I told him not to go to Kwik-Fit.
Lesson learned
loggyboy
| posted on 8/4/11 at 10:41 PM |
Whats an oil reservoir?
Ben_Copeland
| posted on 8/4/11 at 10:44 PM |
Sump??? Fancy MOT talk for sump probably
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
Macbeast
| posted on 8/4/11 at 10:51 PM |
Brake fluid reservoir ?
If they fitted new pads they would probably have pushed the fluid back into the reservoir.
se7en
| posted on 8/4/11 at 10:52 PM |
I assume it was the power steering reservoir. Cant think of any other oil reservoir.
He took the Astra to small local garage and they sorted it all out for £20.
MikeRJ
| posted on 8/4/11 at 10:59 PM |
Never heard of failing for too much oil unless it was leaking or causing a smoke screen
Ben_Copeland
| posted on 8/4/11 at 11:04 PM |
Didn't think they checked reservoirs anyway? Can't say I've ever seen a tester check them.
Ben
Roadster
KitCatE1
| posted on 8/4/11 at 11:08 PM |
had my car mot'd yesterday they didnt check any of the fluids, i was stood next to the car strange
norfolkluego
| posted on 8/4/11 at 11:58 PM |
Wouldn't have thought you could overfill brake/power steering reservoir, you just brim them don't you.
Must be something else they're talking about.
speedyxjs
| posted on 9/4/11 at 08:49 AM |
Fluid levels are not checked on MOT. Not quite sure what it could be!
iank
| posted on 9/4/11 at 08:57 AM |
Might have been an advisory rather than a fail.
Anonymous
adithorp
| posted on 9/4/11 at 09:08 AM |
I've never seen a high fluid level fail a test at an MOT in 30+ years in the trade. Brake fluid level is checked to make sure it's not too
low (advisory and gives them a clue to look for leaks) and I've seen diesel smoke tests abandoned due to low engine oil in the past, but not
recently.
Nope! They both have "max/min" levels. Don't over fill as that space allows for heat expantion.
http://jpsc.org.uk/forum/
norfolkluego
| posted on 9/4/11 at 11:31 PM |
recently.
I never knew that, I've always just sloshed it in. Note to self, the marks are there for a reason.
