loggyboy
| posted on 10/12/12 at 11:12 AM |
1.8 CVH flywheel & clutch
Are these worth anything? Are they used in any conversions etc? Only reason I ask is that im weighing in a load of metal and if its popular and worth
more than a fiver I may as well flog it on here or ebay, if not Il just stick it in the scrap pile.
Mistral Motorsport
scutter
| posted on 10/12/12 at 01:11 PM |
If it has the EFI trigger notches on the rear face then it could be worth something as they are a bit lighter than the zetec ones and will fit with
the bolts opened out to suit. Don't know how much tho.
ATB Dan.
loggyboy
| posted on 10/12/12 at 01:48 PM |
ATB Dan.
It was carbed so i doubt any notches, however there was a trigger wheel and sensor on the crank pulley.
Mistral Motorsport
whitestu
| posted on 10/12/12 at 03:07 PM |
I fitted a CVH flywheel to my Zetec. It was a couple of kilos lighter that a 1.8 Zetec job.
Stu
loggyboy
| posted on 10/12/12 at 07:56 PM |
Stu
What clutch, realease bearing etc did you combine it with?
Mistral Motorsport
pmc_3
| posted on 10/12/12 at 08:37 PM |
I've used one to mate my rst engine to a type 9. I used a 2.0 pinto clutch and release bearing and a 1.8 cvh starter
whitestu
| posted on 10/12/12 at 08:50 PM |
Stu
As I had a 1.8 CVH in the car already that had a new clutch kit I used that.
Stu
AdrianH
| posted on 10/12/12 at 09:01 PM |
I have done similar with a 1.8 Silvertop.
Used the 1.8 CVH flywheel drilled out the holes, Used the crank pulley on the front of the engine and fitted a bracket to hold the sensor.
Adrian
Why do I have to make the tools to finish the job? More time then money.
