Not Anumber
posted on 1/10/13 at 05:01 PM |
What a thoroughly excellent job theyve made of that retropower CF. Seeing that and reading this has made me think of taking on a van project next
timbedford
posted on 1/10/13 at 07:46 PM |
Indeed, its a beauty isn't it. I have inquired with retropower about doing mine, but rightfully that's a lot of money and they won't
do things by half measures.
Britishtrident sounds like you had some bad experiences with CFs. Its no aston martin i grant you, but mine will cheerfully hold a straight line of
its own accord. I often drop a brick on the pedal and jump in the back to brew up a cuppa and I've hardly ever crashed.
It would be a boring old world if we all liked the same thing though. I'm going to go and find a thread about Vauxhall zafiras now to tell the
owners what I think of them.
timbedford
posted on 1/10/13 at 08:01 PM |
quote: Originally posted by Not Anumber
I was thinking more straight swap for the Carlton/ Omega version of that engine for £ 200 to £ 300 from a breaker or Ebay seller. The van versions
were always low compression so it will be a cheap and easy win for the next stage and will let you build on what you have.
The door is then open for some porting and polishing of the head, a fast road camshaft and possibly megajolt ignition for the next incremental stage.
This is appealing.
redturner
posted on 7/10/13 at 07:41 PM |
Just caught up with this thread. I worked on the CF s when they were new and had to be the worst truck ever. They were fitted with all kind of engines
and not one seemed to do the job. Perkins 4.108 great in a boat, not a Bedford. Opelless diesel, even worse, setting the FIP up was a nightmare and
needed two men or at least a boy to lay underneath to rotate the crank whilst you set the pump up with the dial gauge. a variety of petrol engine,I
think maybe the 2.2 was the best. For modern day running go for something like a 2 litre Black Top Zetec. Had a look in one of my cupboards and I
still have the original pump adaptors and dial gauges in a wooden box.....
