corrado vr6
| posted on 20/5/13 at 02:43 PM |
Can anyone machine these out of 3mm Ali
Hi there,
Is anyone able to machine me these? I need 6 rings in total all with a hollow centre so I'm left with a 12.5mm ring
They need to be made from 3mm Ali
Obviously willing to pay
Thanks in advance
Greg
http://r1indy7.wordpress.com/
Matt_C
| posted on 20/5/13 at 03:00 PM |
Machining would be a very expensive option. Would be much cheaper and easier to have them laser cut or waterjet cut from ali. Both of these are always
a cheaper option than machining on any 2D shape.
Places I use would be too far away from you, if you just google it I'm sure you can find local places.
trextr7monkey
| posted on 20/5/13 at 03:15 PM |
Fly cutter in drill and just go steady! I don't think we have any ali that thick knocking about could check in the morning, we made similar
things once for a bloke changing down lighters in his 70's house
What is their application, tolerances, required finish etc?
atb
Mike
corrado vr6
| posted on 20/5/13 at 03:48 PM |
There just to mount some lights strangley in a jago!
They won't be seen so haven't got to be to special, but i don't have the tools unless I chain drilled then filed them to shape which
would take a while to do 6
They haven't got to be mm perfect just there abouts really
Edited to say I could supply a sheet of Ali if its something you think you could do?
[Edited on 20/5/13 by corrado vr6]
trextr7monkey
| posted on 20/5/13 at 04:38 PM |
just sent a u2u
T66
| posted on 20/5/13 at 04:59 PM |
Isnt there a locoster who has a water jet cutter ?
matt_claydon
| posted on 20/5/13 at 05:31 PM |
As above, don't machine, use either laser or waterjet. I think it's andyw7de on here who has a waterjet.
You could do it yourself with two hole saws, although you won't get exactly those dimensions. 76mm and 86mm are readily available, but pretty
sure I've seen 90mm.
T66
| posted on 21/5/13 at 10:34 PM |
http://www.mig-welding.co.uk/forum/showthread.php?t=40595
