Author: Subject: Mini welding
steve8274
posted on 16/8/13 at 09:39 PM Reply With Quote
Mini welding
Just purchased myself a c plate mini in need of some bodywork.
Can anyone recommend a welder who has knowledge of minis who operates in northwest(even better wigan&#128540
Needs inner and outer sills, a panel and front wing. Probably uncover more rust later
ianclark1275
posted on 17/8/13 at 07:26 AM Reply With Quote
if you dont get much response then try theminiforum,
IC
measure twice, cut once, scrap it, start again.
minitici
posted on 17/8/13 at 08:34 AM Reply With Quote
Any welder with experience of Minis will run a mile!
tegwin
posted on 17/8/13 at 08:59 AM Reply With Quote
This is the locostbuilders forum so I would suggest you buy a decent welder (not a pants hobby one) and do it yourself. How hard can it be :£
www.verticalhorizonsmedia.tv
Minicooper
posted on 17/8/13 at 12:01 PM Reply With Quote
There are lots of quotes for welding stuff on the various mini forums and these days it seems to run about £360/£400 per side for inner and outer sills, probably door step, floor pan, flitch repair patches as well included.
You can easily spend a thousand quid on what looks like a reasonably good mini.
It's not easy to weld thin metal well, but with practice you should be able to do it good enough
jacko
posted on 18/8/13 at 03:07 PM Reply With Quote
Spot on i was asked to weld a mini a week or so back
